Mach 15 Questions on Condenser Fan
w4yn
How do I tell if condenser fan in on shaft correctly?
Also how far into the shroud fan be?
Tim
3 REPLIES 3
w4yn
Old-Biscuit wrote:
Condenser fan blade should split the shroud opening...half in/half out
Screw that tightens blade onto shaft is towards motor
Thank you that is what I needed, fan came with blade outside of shroud. Now all is good, for now!
Tim
Old-Biscuit
newman_fulltime
measure off the old one where it sat on the old one
