Magnetic dipstick for generator
ib516
Has anyone installed one of these from Amazon in a non-Honda portable generator? I have a Firman 3300w inverter and have the magnetic dipstick in my Amazon cart but not sure it will fit. They are all advertised as being "for Honda" or "for Yamaha".
Surely someone here has one they installed in a Chinese genset...
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
9 REPLIES 9
Gjac
pianotuna wrote:
Hi,
Ummm most of the generator dip sticks are plastic......
Gjac wrote:
You can magnetize your dip stick by sliding a magnet across the tip multiple times. I did this on my 54 Ford in high school it works but a magnetized drain plug or a magnetic on the outside of the oil pan will work better.
Mine is steel but it is old.
pianotuna
Nomad III
Nomad III
Hi,
Regards, Don
SaltiDawg
pianotuna wrote:
Hi,
This is off topic--but I am going to try this for my genny oil changes:
https://www.amazon.com/Fumoto-F-109N-Engine-Drain-Valve/dp/B003VCDABU/ref=sr_1_1?ie=UTF8&qid=1518279...
I use this for my home "portable" generator.
Absolutely great!
Took some doing to find out the correct thread on the generator.
RJsfishin
If theres metal in my oil I don't want to know about it ! :))
Rich
Gjac
Kpackpackkelley
Iโ€™d rather have the threaded drain plug magnetized. When you change the oil clean it off. But I guess the dipstick would work a well just make sure to get the right length.
pianotuna
Nomad III
Nomad III
Hi,
Be sure to order the right size! I was gifted a beautifully machined one--that was too small.
Regards, Don
gbopp
As an option, can you get a magnetic oil drain plug?
kerrlakeRoo
That units engine is a Honda "clone" 171 cc G-42 series if that helps. Old 1970's design.
Chinese made, most parts fit, but not all.
