microlite 2.8KV
rldavis
Onan Microlite KV - model 2.8KVFA26100K - spec K
Generator was starting and running 120 no load 115 load for 20 minutes and would die. Gradually reduced running time to under 2 minutes.
Now will start and run only with the start button down. Initially would do this and produce voltage - now produces no voltage.
I have cleaned the slip rings and replaced the brushes. I cleaned the brush block (brushes were not stuck) the block is not cracked or damaged so reused it.
I had the rotor and stator megged at a service shop and both tested good.
I tested the VR and according to book it is good (But can still be bad.
Ran 12 volts through pin 9 and grounded pin 10 of the generator side of the VR connection - no volts.
This is supposed to bypass the VR - what have I Missed???????????
Thanks,
Robert Davis
2 REPLIES 2
64thunderbolt
When was the oil changed? I bought a WW once and the 2800 would die when I loaded it. Changed the oil and wala. The oil I drained out was as thin as water. It never gave me a problem after that. The PO just neglected it. Shame it was neglected that way.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
Kpackpackkelley
Magneto is what I would look at. . Do you have the service manual ?
