Just came home with another travel trailer. 2015 Jayflight 32 BHDS. It has a KIB monitor panel with the switches for water pump, electric and gas water heater operation. All of the switches function, water pump runs and gas fires on the water heater. Here’s my issue, none of the lights work. The switch lights do not come on and none of the lights come on when I press the tank levels or battery level. Anyone have a suggestion on what it could be. Everything else in the trailer operates as it should.
2010 Toyota Tundra SR5 TRD double cab 4x4
2015 Jayco Jayflight 32 BHDS
Prodigy Brake Control
Eaz-Lift WD - Eaz-Lift sway control
