โApr-24-2016 05:10 PM
โMar-03-2024 10:47 PM
when i go to the link for your video about the foam , it says private. could you send me a link to your video ? dverseboy@gmail.com
โMar-04-2024 02:18 PM
Evy's last post was 2019. Hopefully they are still around.
โMay-30-2016 08:32 PM
โMay-30-2016 08:14 PM
โMay-30-2016 08:11 PM
free radical wrote:
I guess its too late now since you already have the foam,
however this would be much easier to do this with one of those guns that you screw the expanding foam can into,,
Its just a handle with trigger and about foot long nozle,,gives excelent control as you can spray it very slow or fast and stop anytime..
Hint..to screw the expanding foam can onto this it helps to spray WD 40 onto the gun tread..
Also theres a special cleaner sold in presurized cans to clean the nozle after
All these are sold in Home depot or most hardware stores..
โMay-30-2016 07:59 PM
โMay-30-2016 07:03 PM
โApr-29-2016 09:00 AM
myredracer wrote:
Talk to a company or individual that has done Class B van conversions or search the internet. For example, here's a guy who did a conversion and used spray foam insulation and sounds like he did a bunch of research first. Build a green RV
โApr-29-2016 08:32 AM
โApr-29-2016 08:21 AM
DutchmenSport wrote:
"evy, I believe that you have already made up your mind and are only seeking affirmation of your decision."
I also drew the same conclusion when the OP posted his FIRST rebuttal. Unfortunately, when I was typing, he had already posted. Otherwise, I would have never responded at all.
I also say, "Good luck!"
โApr-28-2016 03:30 PM
โApr-28-2016 02:06 PM
bob_nestor wrote:
Spray foam, when installed by someone who knows what they're doing, doesn't cause damage thru expansion. It just needs to be sprayed a little at a time in layers.
I had open cell spray foam installed in the house I'm renovating. I wanted it in the ceiling, and to do that I laid construction paper over the tops of the joists and stapled it down. The insulation contractor sprayed into the that and there were very few places where the pressure from expansion displaced the paper, usually only in areas where I didn't put in enough stapes. Never saw one place where the paper was torn from expansion, but I did see a lot of small nooks and crannies that were nicely filled with the foam.
There are also different formulas for the spray foam and you can see that in the types available at home improvement stores. The formula recommended for use around doors and windows expands but only to the point where it meets an obstruction so it doesn't warp the frames.
โApr-27-2016 09:11 PM
evy wrote:Naio wrote:
IMO (!) your thinking is quite sound about encouraging expansion upward by pouring in short layers. I agree that it would be wise to test the theory first, because why not?
How does condensation work with spray foam on a metal wall? S&B house walls are designed to pass water vapor out through the exterior walls.
I did some tests in my house once. up here we have cold winters so insulation is very important.
I installed 1.5" rigid insulation boards on a concrete wall (industry standard at the time, today it's 3")
I installed 1.5" of polyurethane foam from a can directly on the wall
I also left a part of concrete completely exposed
after a week of -4F temperatures this is what happened when I removed everything.
The exposed concrete had 1/4" of ice on it, from the condensation freezing on the concrete who was acting as a thermal bridge (just like the van's outer panels).
After removing the 1.5" rigid insulation it had frost and some thin ice behind it, because it was not completely and perfectly in contact with the concrete.
And after removing the polyurethane with a scraper, it was completely dry and not even cold.
The enemy is air pockets, voids, cavities call it what you will, when air moisture touches a cold panel it will condensate and maybe freeze or drip depending on how cold it is.
So this is what my theory is based upon, filling the voids, having no air at all. If for some reason the polyurethane gets loose and creates an air gap between the foam and the outer panel, moisture will condensate and drip to the bottom and eventually rust, but by filling the space completely all the way to the top, I think it will hold.
Today it is around 48F so it's still too cold to do a test, 75F to 80F is the right temp...
โApr-25-2016 12:12 PM
greenrvgreen wrote:
P Tuna is talking about my suggestion, and the OP is rather touchy. Then again he's talking about living inside a van.
Yes Tuna, the open-caell idea is going to fail the condensation test. In fact ANY insulation that is not itself a moisture barrier is going to become a moisture habitrail. I'm trying to think of something that would smooth out the obvious corrugations in the roof/upper wall treatment. Ensolite will do this, and is closed-cell.
IMO, the van presents certain unique challenges, IMO. #1 IMO the metal skin is highly conductive, and #2 IMO is doesn't breathe the way that metal siding can and does, IMO.
Again, IMO I think the OP's made good progress IMO and some sort of shot foam is called for in the lower areas IMO. I wouldn't mess with chunks IMO just fire away with the foam.
IMO.
โApr-25-2016 12:08 PM
