โDec-06-2019 05:14 AM
โDec-06-2019 10:07 AM
crcr wrote:ktmrfs wrote:Ed_Gee wrote:
Recommend this place for high quality solar materials:
AM Solar
x2.
Thanks. Nice looking wire, but two problems with it -- that is 10 gauge -- I'm looking for 8 gauge as mentioned in my last post. And even at that, this 10 gauge roof wire is pricey at $3 a foot plus shipping!
โDec-06-2019 09:52 AM
pianotuna wrote:
#10 is not big enough unless you are going to MPPT controller with a high voltage input. Even then you may wish to do #8 or #6.
Try Home Depot. You can select UV and gauge 6-2 or 8-2
โDec-06-2019 09:50 AM
C Schomer wrote:
I redid my panel wiring last summer and I put any exposed wire in conduit. I also cut out all the plug connectors and crimped/soldered. One off those plugs easily pulled apart... Very poor internal crimp. Craig
โDec-06-2019 09:49 AM
BFL13 wrote:crcr wrote:BFL13 wrote:
I used ordinary #8 black and red, no UV. The red goes pink after a while if left exposed. I used plastic split wire sleeving over the exposed wires on the roof. No UV protection in that either AFAIK, but will replace when that deteriorates. If the 1991 RV outlasts that!
Thanks, yeah, I was considering doing just that! So you covered the wires with commonly available split wire loom?
Yes. I was able to pair the black and red #8s into one split loom from each panel. Can't remember size of loom , 1/2" ? Used Eternabond strips here and there to hold it down
A good lesson learned the hard way, is leave the panel pigtails to stick out past the panel when the panel is lying down. Now you can add your wire to that. It gets complicated if you have to add your wire to the panel first before laying it down, and then you can't get at it if your connection isn't connecting right.
โDec-06-2019 09:40 AM
โDec-06-2019 09:17 AM
โDec-06-2019 09:12 AM
โDec-06-2019 09:00 AM
โDec-06-2019 08:57 AM
โDec-06-2019 08:47 AM
AM Solar
x2.
โDec-06-2019 08:19 AM
AM Solar
โDec-06-2019 08:14 AM
โDec-06-2019 08:05 AM
โDec-06-2019 07:17 AM
โDec-06-2019 07:15 AM
