Need help regarding solar installation..
CapeM1
I am going to mount four solar panels onto the roof of our Rockwood 2607. I am looking for the best sealer to use for the mounting brackets. Any other advice would be appreciated. Thanks!
2010 Rockwood 2607
2016 Chevrolet Silverado 2500, Ext Cab
10 REPLIES 10
brulaz
I used 3M 4200 adhesive sealant to help the screws a bit as they were only going into plywood, not the framing. But as it's glued to the rubber roof, whether that helped or not depends upon the strength of the rubber roof and its underlying glue.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
CapeM1
Thanks for all of your help.
2010 Rockwood 2607
Rbertalotto
Might get some good ideas here:
www.rvbprecision.comwww.rvbprecision.com
Good Luck!
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
dapperdan
CJW8 wrote:
Dicor
X2! That's what the experts use, that's what I used.
Dan
westend
pianotuna wrote:
Dicor and make sure the controller has adjustable voltage set points, as well as a temperature probe on the battery bank.
X2
An alternative to goop: Eternabond screw sealing.
I've use the Eternabond Roof Repair tape and Webseal with the same results. It's amazing to see the fastener head disappear.
'03 F-250 4x4 CC
pianotuna
Nomad II
Nomad II
Regards, Don
Boon_Docker
Self-leveling Dicor
Chandalen
Get a good solar controller, not the one in a kit. Morning Star makes great controllers.
Never connect solar panels to batteries without a controller in the middle. You will over charge the batteries, and with cheap panels actually discharge the batteries at night.
As mentioned above, use decent gauge wire. 6ga or dual 8ga from panels to controller, and the same to the batteries is great. From batteries to an inverter (depending on size of inverter) you will need much thicker cables. I use dual 1/0 wire from my batteries to my 2k Pure Inverter.
Verify shading of the panels on your roof. ie make sure the AC or skylights are not close enough to any panels to cause shadows.
BTW Harbor freight panels are utter trash and should not be used.
'08 Sierra 5th wheel bunk house
'04 F350 6.0L (bulletproofish now)
470ah GC2 battery bank, 500w Solar /w TS-45 Controller, 2k Pure Sine Inverter
Active Duty Army
corvettekent
Dicor Self-leveling Lap Sealant.
Mount your controller close to your batteries and use as short of wire run as you can, also use 6 or 8 gauge wire.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
CJW8
Dicor
2003 Forest River Sierra M-37SP Toy Hauler- Traded in
2015 Keystone Raptor 332TS 5th wheel toy Hauler (sold)
2004 Winnebago Vectra. 2011 Jeep Grand Cherokee toad
