Need your thoughts
suprz
My Onan micro quiet 4000 has always taken a few moments to start up when cold, but recently I have noticed that once running and warmed up after about 30 mins it starts to surge and gets progressively worse. I shut it off and it wouldn't start back up. I have the bay door open for ventilation, but I keep the access door on the generator because i know it needs it on for the cooling to work efficiently. I changed the oil and air filter recently. This last time it acted up it wouldn't start, I went outside and tried to start it from the switch on the generator itself. It still wouldn't start. I primed it and tried again and was successful after a few cranks.. But I just shut it off and let it be for now. This scenario happens if there is a load on the generator or not. I'm thinking fuel filter? Or maybe the pump stops once it gets too hot? Or vapor lock? It's only around 62 degrees today, so I don't think it's overheating.
Proud father of a US Marine
9 REPLIES 9
DFord
Mine is spec K also. It calls for 1.5L but I can't buy it like that so I ran the conversion. After it sits awhile, you can verify the correct level.
If you change the oil and put 1qt 19oz back in, it'll be 2 teaspoons over full (if you get it all in without leaving some in the bottle).
I had the same problem you're experiencing and ended up overfilling trying to go by the dipstick on the end of the plug. That caused some of the excess oil to end up blowing out the air cleaner breather tube. Now that I've got the right oil charge, that's not a problem anymore.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
suprz
DFord wrote:
It's hard to believe that so many ask for help with a problem yet give so little information about the equipment. There's no way to give a correct answer about an Onan Generator without knowing the complete model, serial number and "spec".
I have an Onan Micro Quiet 4000 generator on my MH. The capacity of the oil sump is 1.6 quarts (or 1 quart 19 ounces).
Because air can get trapped in the crankcase, it can effect the apparent level of oil when checking it through the oil fill hole. That trapped air can be negative or positive making the oil level appear to be high or low at the oil fill.
The best way to check the oil level is to do it first thing in the morning before starting it when pressures have equalized.
The best way to make sure you've got the correct amount of oil in the crankcase is to drain it and refill it with 1 quart, 19 ounces of fresh oil.
It is a spec "K"
DFord
Don Ford
Charley67
I would look at the spark plug. If thatโ€™s the culprit it would be a cheap fix.
suprz
I was just watching a youtube video that describes the problem with the generator. It seems that the oil dipstick is incorrect on these gens. I did an oil change recently and put the oil to the full mark. According to what I have read, and watched, the oil can be too full and cause the issue I have described. In any case, I have suctioned out enough oil so the oil level now reads in between the full and low mark on the dipstick. I will try the generator again tomorrow and see if that has any effect.
time2roll
If an Onan tech wanders by they are going to want the exact model and serial numbers.
Matt_Colie
Suprz,
It might just need a spark plug or the carburetor cleaned. Find a local small engine shop and get them to look at it. Onan engines are used all over the place, and the can probably supply aftermarket parts that Mr. Cummins is not so proud of.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
suprz
jplante4 wrote:
Fuel filter or fuel pump. The filter is cheaper and easier. Is there more than a quarter tank of fuel?
Yes, a bit over 1/2 a tank, that has been treated with Seafoam
jplante4
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
