Jun-13-2022 10:45 PM
Jun-16-2022 01:49 PM
Jun-16-2022 12:57 PM
Jun-16-2022 11:22 AM
Jun-16-2022 10:16 AM
3 tons wrote:Agree, cell quality and testing is very important. However, there's another significant issue to consider when comparing a 12v 100ah Battleborn battery to other 12v 100ah lifepo4 batteries on the market.
Another factor (though widely overlooked…) that impacts longevity is determined during the manufacturing process via final testing, and suggest the cost difference between say a BattleBorn or an Aims (grade ‘A’ cells), versus the bargain brands . . .
Jun-16-2022 09:59 AM
BFL13 wrote:Between the solar and the old PD I believe the OP is in great shape to get very near maximum life from the LFP fully automatic and easy.
Or if you hate manual and want automatic, win the Lotto and not care about cost. Easy! 🙂
Jun-16-2022 09:08 AM
SFVdave wrote:
When I installed lithium batteries 18 months ago I also changed out my converter charger. I didn't want it constantly charging 14.4 volts. so I returned it and have been using my original PD converter charger and just hit the charge wizard to get it fully charged. With 300 watts of roof top solar and an MTTP controller, it stay fully charged shile camping. But I heard that PD was going to produce a 2 stage one that drops to 13.6 after fully charging the batteries. Wondered if they came out with it? Can't find it on their site if they did. they have changed the num,bers around with upgrades so I may have missed it.
Jun-16-2022 08:02 AM
Jun-16-2022 07:37 AM
StirCrazy wrote:I stand by my comment: "14.6v nets you maximum ah's and minimal charge times at the expense of cycle life". I'm not claiming it's a large, or a small amount, I'm simply claiming that there is a drop in cycle life, which is a true and correct statement.otrfun wrote:Im not sure the way this part is worded is the best. and it could be leading to a lot of the confusion.
Good question. Depends on what you want from your lifepo4. Maximum usability? Maximum cycle life? Or, something in the middle?
14.6v nets you maximum ah's and minimal charge times at the expense of cycle life.
You can charge a 12v lifepo4 with any voltage between say, ~13.15v and 14.6v with varying degrees of usability and cycle life. 14.6v nets you maximum ah's and minimal charge times at the expense of cycle life. ~13.15v nets you maximum cycle life with reduced ah availability and increased charge times.
There is no one charge profile that provides both max usability and max cycle life. It's either one or the other, or a little of both.
Pick your poison.
I think it would be better to say "advertised cycle life" instead of "at the expence of cycle life" some one like BF13 or PT might interpret that as by charging to 14.6V we are only going to get 1800 cycles now.
the max figures are what the cycles are based off so 14.6 charge 100 to 0 discharge, but yes like you say if you don't need all of your battery bank operating between say 80 and 20% would normaly take a 3000 cycle battery up to the 5000 cycle range and using less than 50% so 30 to 80 could take you up to 7000 cycles. so there is a big trade off, but generaly to get more life you have to spend more on batteries to let you use that smaller amount of capacity.
Im trying to figure out how to set up my peramiters on my solar charger to stop charging at 90% right now, but I have 10x my daily use capacity so using 90% as my celing should gain me a tone of life that I probably won't live long enough to see anyways haha
Jun-16-2022 05:36 AM
Pick your poison.
Jun-15-2022 07:13 PM
Jun-15-2022 07:10 PM
Jun-15-2022 06:48 PM
BFL13 wrote:Good question. Depends on what you want from your lifepo4. Maximum usability? Maximum cycle life? Or, something in the middle?
. . . I am unclear what goes on with LFPs for that, where many say 13.6 is too high with LFP for "Float", but is it too high for while camping using 12v things? Perhaps there should be a new set of voltages for LFP for what to use while actively camping and what to use when the rig is not being used? . . .
Jun-15-2022 06:22 PM
Jun-15-2022 05:09 PM
Jun-15-2022 03:21 PM
