Our trailer came with the "upgrade" version of the flooring, a mix of tile and carpet. The upgrade was the standard $1.00 a square foot lino had lino tiles ($2.00 a square foot?) here and there instead of the regular lino.
🙂The carpeting was arranged so you could not get from the doorway (tiled) to the bathroom (upstairs via carpet) to the bathroom (tiled) without stepping on your carpet with your muddy boots on. (No good at dog events)
The strip of carpet in the main living area was what the slide ran over and it did have a thin underlay. Unfortunately the dogs barfed enough that this carpet became unsat
🙂 (It wasn't that great anyway--maybe the dogs had a point)
So out came the carpet except for the bit on the slide, to be replaced by other cheapo tiling, installed by me. Komfort tech support told me to at least leave 2" of carpeting by the plastic round-down the slide rides coming in/out at the outer edge of the main floor.
I ignored that advice since it was inconvenient. So the slide scratches the new tiles I put everywhere on the main floor and stairs. Wax fixes that when we get keen.
So that strip of OEM carpet at the edge of the floor is what keeps the slide from scratching things before it gets to any tiling or lino in the kitchen or where ever.
So the issue now is can that carpet on the main floor that goes under the slide be too thick or high up so it gets damaged? No idea.
I sure would not put wooden plank flooring down there or it would be wrecked, since it is too high (thick) based on how the thin tiling I did gets scratched.
Lately I have been at a carpet place who has some Berber that they say does not need the edge bound, and it will not fray and they even have a warranty that it won't.
I have been thinking of re-carpeting with that for the slide and part of the main floor nearest the edge under the slide. If true, no need for getting the slide carpet floppy edge bound.
The rest of the floor farther over, past where the slide covers, can be any height (thickness) I want, even those wooden planks. This might be the next reno!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
