No hot water in electric mode
joesann
I have a KZ travel trailer with a Suburban Water Heater model sw6del. On our last trip, was using the heater in electric mode for a few days. Then it stopped working in electric mode. Switched to propane and we got hot water to finish our trip. I did not have time to look at it before we returned home. Just asking for idea's of what to look for? Any ideas would be great! Thanks
5 REPLIES 5
Old-Biscuit
DEL model uses DC for electric & propane functions
But with propane working DC is present
So issue is with AC side (or the 'DC Relay')
Wiring diagram to help troubleshoot....Voltmeter
sljkansas
When mine died it was the water heater's heating element. It was corroded. and the Element was bad. I went to the hardware store and bought a new element.
You will need a heating element socket and a screw driver. it's really an easy fix
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter Married.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
BB_TX
Possibilities;
Tripped breaker
Bad switch on bottom left corner of water heater
Bad thermostat/hi temp cutout switch
Loose wire (junction box on back side of WH)
Bad heating element
Start tracing with a voltmeter until you find the point of no voltage (assuming you are comfortable troubleshooting 120 vac)
donn0128
Grab a volt meter and start checking. Temp sensor packs are a common issue, as are the switch in the lower left
USAFBILL
My first thought would be the electric element, cheap and easy to replace.
2003 Cougar 285EFS
2000 Chev 2500 Ex Cab
