Apr-27-2018 10:38 AM
Apr-29-2018 05:15 AM
wnjj wrote:
Are you sure there’s not another GFCI in the fridge compartment? If the fridge works on electric that wouldn’t the be issue, though.
Apr-28-2018 07:00 AM
doxiemom11 wrote:It's a camper so I doubt it's 50A.
Are you plugged in? If so, are both legs of power good from the box?
Apr-27-2018 08:18 PM
Apr-27-2018 06:32 PM
Apr-27-2018 04:42 PM
westend wrote:
I'd suggest to check for moisture in the exterior receptacle. It may be protected by the GFCI inside the camper. Some RV's come equipped with a separate GFCI for the exterior circuits (typical).
Apr-27-2018 04:04 PM
Apr-27-2018 01:30 PM
Bud
USAF Retired
Pace Arrow
Apr-27-2018 11:53 AM
Apr-27-2018 11:28 AM
Bud
USAF Retired
Pace Arrow
Apr-27-2018 11:18 AM
donn0128 wrote:
Your positive you have only one GFCI? Start at the breakers, flip them off and back on. Then start at the first dead outlet and open it up. Using your VOM check for voltage. Yea? Move on. Nay, start looking for loose wire. My guess your going to find a loose push on connection. If so, replace with a regular screw terminal outlet.
Apr-27-2018 11:16 AM
Dutch_12078 wrote:
Check those outlets carefully again, especially the one in the bathroom. That one is typically a GFCI. Also check your breaker panel, the breaker serving those outlets could also be a GFCI.
Apr-27-2018 11:11 AM
Apr-27-2018 10:41 AM
