Norcold 1200 refrigerator fan wiring question
ArchHoagland
I have a pre 2006 Norcold 1200 refrigerator that the two cooling fans on the condenser ceased operating after the refrigerator was worked on for a heating element problem.
Research has led me to believe the tech installed the black and white wires that supply 12 volts to the fans incorrectly.
If someone who has a 2005 or older RV with the Norcold 1200 refrigerator could look at their control board tell me how their board is wired I'd sure appreciate it. There are two wires that go to the fans....a black and a white.
As you look at the control board is the black wire on the right or left connector?
You can see the wires without removing the cover on the control board.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
8 REPLIES 8
dougrainer
Sorry, got busy. WHITE is on the left. Doug
JC2
Ivylog wrote:
I doubt it makes any difference...try reversing the two wires. Too bad a pair of wires were not run from the temp switch so you could manually turn on the fans to test.
That's what we have always done; run the fan wires directly to a simple on/off switch mounted inside the rv on the wall close to where the fan(s) are.
2010 Newmar Dutch Aire 4304,Cummins ISL 425hp,Spartan MM Chassis,2013 Chev Equinox AWD Towed,Ready Brute Elite TowBar/Brake,FMCA #402879,SKP#120487
dougrainer
ArchHoagland wrote:
dougrainer wrote:
Yes, IF the 2 wires are reversed the Cooling fans will not operate. VERY common mistake novices make. If all the tech did was r&r the Heating element, just reverse those 2 wires. I cannot remember which is which. I have that info at work. Doug
The Norcold manual has a picture of my control board showing the white lead on the left.
Mine has the black wire going to the left connection.
There is 5 volts DC on that connection.
Could you please check at work and determine if, indeed, the white wire should be on the left terminal.
Thanks.
Just swap them. NOTHING bad will happen. The ONLY thing that happens when they are reversed is the fans do not operate. Since yours do not, the logical thing to do is swap them. Doug
ArchHoagland
Thanks.
US Gear Brakes
SidecarFlip
Bingo
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
dougrainer
Ivylog
Upgraded with a 08 HR Navigator 45โ€™...
Old-Biscuit
Fans wires??
Fans are supplied via circuit board
12V DC POS goes to thermostat on condenser fin and then to fan
12V DC Grd comes from fan back to board
12V DC POS (should be black) would be LEFT
12V DC Grd would be RIGHT
Thermostat....Closes when condenser fin temp reaches 130*F and Opens when condenser fin temp drops to 115*F
