NORCOLD Refrigerator Removal
Grey_Mountain
Refrigerator is belly up. Going to replace with a residential model.
Any tips on how to get the existing fridge out of the motorhome?
Thanks.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
13 REPLIES 13
larry_cad
Congratulations!
Today is my personal best for most consecutive days alive.
Our Travel Blog
Cptnvideo
We removed a 18cf Norcold and installed a 20cf Whirlpool thru the door of out 5th wheel Solitude.
Bill & Linda, 2019 Ram Laramie 3500 dually 4x4 diesel, Hensley BD5 hitch, 2022 Grand Design Solitude 378MBS, 1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LFP batteries for 1030 ah
pianotuna
Nomad III
Nomad III
Thanks for letting us know!
Regards, Don
Grey_Mountain
Old fridge out, replacement in. Through the door. Fairly easy job.
Installed a Magic Chef 10.1, $499.
Thanks for all the tips.
GM
Honda CR-V Toad
English Bride
larry_cad
Grey Mountain wrote:
allbrandauto wrote:
my norcold 1200 went through door of 24 and a half inches by removing norcold front doors installed samsung the same way
I will also consider that option.
Thanks.
GM
This should work, if you remove the frig doors, and maybe the RV screen door. That worked for mine when I did it.
Our Travel Blog
Grey_Mountain
Thanks.
GM
Honda CR-V Toad
English Bride
allbrandauto
Grey_Mountain
I have a tractor with a front end loader. Looks like through the window is the route to go.
Thanks for the information.
Getting ready to seel the rig.
GM
Honda CR-V Toad
English Bride
craig7h
Nomad II
Nomad II
Have you thought about just replacing the cooling unit? I replaced my norcold cooling unit two years ago with a totally 110v system works great. You may want to look into JC Refrigeration products. Its really an easy DIY process. https://jc-refrigeration.com/
Its not getting the old one out but the new one in. A lot of folks have done it so hopefully one of those will help.
Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
Grey_Mountain
Looks like out the window is the way to go.
GM
Honda CR-V Toad
English Bride
Community Alumni
Not applicable
My old Refer went out the large window onto a fork lift or 6 guys on a pickup
New one went in same way.
get lots of help
JimR
pianotuna
Nomad III
Nomad III
Ummm how will you get the new one in?
Regards, Don
2oldman
Found some vids about Dometic removal.. may be of help.
