not inverter again
wanderingbob
If all I am ever gonna run is a 24 inch TV , how large of an inverter am I a gonna need ?
9 REPLIES 9
time2roll
I recommend 300 watt GoPower SW or 350w Victron SW.
wa8yxm
If that is all you want get a 12-14 volt TV. Some Samsungs are 14 volt
DrewE
enblethen wrote:
Look at the power plate on the TV in question. Get an inverter at least 70 per cent of this for TV alone. If you have other devices such as DVD player add it's wattage.
My guess it would be around 300 watts total for continuous rating of inverter.
For a modern LCD or LED TV, the power consumption will be well less than that, maybe around 35W or so for moderately sized units. CRT TVs (and doubly so plasma TVs) are power hogs in comparison.
Incidentally, an LED TV is generally just a LCD TV with LEDs for the backlight rather than cold cathode fluorescent lamps.
GordonThree
Ivylog wrote:
Is it a LED or a LCD TV?
Anything that size will be an LCD panel with either fluorescent or LED backlight.
OLED displays are much smaller (cell phone or laptop) or much larger (55" +)
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
Ivylog
Upgraded with a 08 HR Navigator 45โ€™...
dockmasterdave
For our 22" smart tv and an antenna booster I use either my jump pack ( lasts about 5 hrs for this ) or my 140 watt inverter that plugs into a cigarette lighter plug.
2014 F 150 ecoboost
2008 Chrysler Aspen
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
Dusty_R
We'v had a TV that was 12v with a wall wart for a 120v power input. It only needed 12v dc to begin with.
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Gulfcoast
I use a 300 watt on my 24" tv. One smaller would work, but the 300 is pretty cheap anyway on eBay.
RV'ing since 1960
Dodge Cummins Diesel
Mega Cab
Jayco Travel Trailer
