Nothing works?
Quick_trip
My fifth wheel trailer sat for 4 years and batteries went dead.
Installed new batteries yesterday.
Nothing works, so I plugged into house with 15 amp power.
Everything works?
Do the batteries need to charge longer to get 12 volt lights to work?
Thanks in advance for any help with this problem.
18 REPLIES 18
Quick_trip
Well, Thanks for all the advice!
They arrived in Albuq. 3 days before the 4th. of July.
They checked the fuses in the battery box and "BINGO" put a new fuse in and all the lights and everything that works 12 volt was correct.
Chandalen
I have a 40a fuse from the batteries to the fuses in the box. Do you happen to also have an inline fuse?
Check the voltage going into the fuse box to narrow down your search.
'08 Sierra 5th wheel bunk house
'04 F350 6.0L (bulletproofish now)
470ah GC2 battery bank, 500w Solar /w TS-45 Controller, 2k Pure Sine Inverter
Active Duty Army
opnspaces
Navigator II
Navigator II
Quick trip wrote:
No, I don't have a meter, so my niece and her husband have left towing
the trailer heading to Alburqurque.
They have a family member who works on RV's
Thanks everyone for your quick replays.
I will let him know what to check.
Cerritos to Albuquerque? That's quite a gas bill to trouble a battery issue.
Gary_
If it was outside there is a possibility of a rodent chewing a wire or two! Good Luck.
old_guy
even if there is no visible corrosion there can be some under the wire insulation. I once had that problem, new wires did the trick.
Quick_trip
westend
There should be a fuse or circuit breaker on the battery's (+) phase cable within a few feet of the battery. Check there first. Do you have a meter?
'03 F-250 4x4 CC
j-d
Necessary Cable NOT connected when batteries/cables replaced. For example, we have four cables connected to positive on our battery. Leave one off, something isn't going to work. I didn't combine them into a common terminal, but I did tape them all together to help avoid missing one.
MEXICOWANDERER
I don't work
Not even with new batteries
Don't feel lonely...
wnjj
Quick trip wrote:
I had new battery cable installed at Camping World along with the batteries.
Could the converter have gone bad?
If 12v things like lights work when on shore power, the converter must be working. What isn't working is the connection from the batteries to the converter.
BTPO1
Dakota98 wrote:
You can always hook-up to shore power & check for voltage reading at the batteries to determine if any charging is taking place.
X2, it would give you a starting point for troubleshooting the problem.
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
Dakota98
Maybe check for "terminal corrosion" at the converter as a next step.
How did the terminals at the battery disconnect look?
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
MrWizard
Moderator
Moderator
Moved from technology corner
I can explain it to you.
1997 F53 Bounder 36s
Quick_trip
Just went out to trailer and yes the battery disconnect was pushed in (off) pulled it out still no lights?
