Nov-09-2023 10:46 AM
Dec-07-2023 07:31 PM
I have a WFCO 8935 that was boiling my batteries. The camper has been plugged in 24/7 with the battery disconnected for over a year without issue.
I'll connect the battery if I need to open/close the slides or operate the landing gear.
Nov-26-2023 10:03 PM - edited Nov-26-2023 10:06 PM
What post am I missing here? Is there a post saying he has 16+ volts or something? How is 12.9 or 13.2 dangerous to the equipment on his RV? Doesn't every RV when plugged in have 13+ volts and 14+ in boost mode?
Nov-26-2023 07:25 AM
I do not know where you came up with your crazy ideas. I have been camping for over 50 years. None of this is safe for the equipment on RV's of any sort.
Nov-25-2023 08:11 PM
Battery has nothing to do with this.
You either have a 12V load that is too high or your converter is having problems.
Also your battery is meant for travelling and short term power. If you have a battery disconnect, I would recommend shutting it off while connected to shore power.
Have you had any recent modifications? (A 12v fridge will do this.)
Nov-23-2023 02:42 PM
Problem Yes.
Because the converter is malfunctioning , the voltage us too high, running from the converter only is going damage the control boards for the fridge, air condition, heater, water heater , maybe burn out your water pump and vent fans, replace your converter, without a battery what will you do if shore power fails, everything will turn off , no heat, no water, no lights, even the fridge b will turn off
Nov-12-2023 06:50 PM
Nov-12-2023 04:26 PM
144Grayling wrote:
Ok. I checked the converter output this morning and it’s 13.2 VDC So it’s in float mode.
Nov-12-2023 08:45 AM
Nov-12-2023 08:40 AM
Nov-12-2023 08:30 AM
ktmrfs wrote:Boon Docker wrote:
His 12.9v reading from the converter (with no battery) is 14.32v RMS.
how do you know that? If the converter is putting out 12.9V DC with little or no ripple the RMS voltage is 12.9V
Unless you LOOK at the output waveform and KNOW what kind of meter is used you don't know what the RMS value is.
Nov-12-2023 06:57 AM
wa8yxm wrote:
I'd need to haul some serious test gear into his rig to make an "Diagnosis" but.
so his 12 volts... might just be poor filtering of a supply with lots of ripple. Or it may be a very smart converter that says "Well I do not sense a battery so I'll go with the lower voltage"
Nov-11-2023 07:27 PM
Nov-11-2023 04:57 PM
Nov-11-2023 03:59 PM
