Apr-01-2021 10:57 AM
May-21-2021 05:29 AM
May-19-2021 07:22 PM
May-19-2021 03:11 PM
23hotrodr wrote:
Does this seem normal? Should the difference of charger output boltage be that much different when connect to a battery?
Thanks for any info you can provide. -- Mick
May-19-2021 05:34 AM
May-18-2021 01:06 PM
30sweeds wrote:
General opinion is you can't leave them hooked up 24-7 like a smart charger.In the auto mode,I can leave mine hooked up as long as I want as the charging rate drops to zero when the battery is fully charged.It will also charge up a stone dead battery.
May-18-2021 07:52 AM
May-16-2021 10:04 AM
May-16-2021 06:48 AM
May-16-2021 06:42 AM
May-16-2021 05:49 AM
Gdetrailer wrote:theoldwizard1 wrote:Gdetrailer wrote:
YES, that is all normal for the old school battery chargers.
Old school chargers (or when using a simple DC power supply) should have a timer. It is very important to make sure the water level is full before starting the charging process.
The boiling is releasing hydrogen which can be explosive in high enough concentrations.
:R
NO, not ALL old school chargers have or had "timers".
Perhaps you can point out WHERE the "timer" is on mine?
Click For Full-Size Image.
You can't, because there is no timer knob on the outside..
And NO, there is NO "timer" inside it either.
That IS pretty much the same charger design that my Dad owned since the 1950s, the internals are the same, a transformer, a rectifier, a self reseting breaker, and the one switch for 6/12V, another in the case of mine for deep cycle/regular.. Those just change what secondary "taps" from the transformer are being used which raises or lowers the voltage.
Now if you are thinking of those 150 lb service station chargers on wheels with 150A starting boost then yeah, those often had a "timer" that you turned which would charge only the time you set it to.. But those were COMMERCIAL chargers, not CONSUMER chargers.
May-16-2021 05:47 AM
May-15-2021 09:15 PM
May-15-2021 08:40 PM
Harvey51 wrote:
Thanks for the first post. I was getting our class C ready for some short trips and somehow drained the engine battery. No problem I thought I’ll just use my Black & Decker smart charger. But it refused to charge. After reading the first post I borrowed a dumb charger and got it charged enough for the smart charger to top up.
May-15-2021 08:01 PM
