โAug-14-2013 08:49 PM
โAug-15-2013 07:15 AM
โAug-15-2013 06:24 AM
โAug-15-2013 04:25 AM
wny_pat wrote:GlennLever wrote:
This is a Fleetwood American Dream. where the heck is the pump?
Glenn,
I suggest checking on the Fleetwood Products Owner's Forum at irv2.com. Am sure that someone there can help you out. Also you could call Fleetwood at (800) 322-8216. And you might want to do a change of ownership with Fleetwood at http://www.fleetwoodrv.com/owners/changeOwner.asp. All kinds of good info on their web page, including a section to download manuals.
โAug-15-2013 04:22 AM
Golden_HVAC wrote:
Hi,
Check out the strainer on the fauscet Remove the screen, and try it out. If you are now getting full flow, then the screen is probably clogged. Clean it out, and everything should be fine. You will probably need to clean out all the fauscet screens.
You should also check the strainers on the pump, and perhaps the shore fresh water inlet. Any of them might also be clogged. If the RV is less than a year old, you might ask the dealer if they will clean them for "Free" - however even if labor is free, it might cost you 20 gallons of fuel to take it in and go get it again. It would only take a few minutes to clean each of the straingers, much easier to do it yourself, unless the dealer is a mile or so away from where the RV is, or you have to go there anyway.
Fred.
โAug-15-2013 04:20 AM
wny_pat wrote:PapPappy wrote:Its a Fleetwood American Dream Diesel Pusher. The engine is under the bed!!! The street water connections would be in the utility bay, and I am sure it is very complicated.
My guess would be that the pump is by the water tank, which may be under the rear bed. Where is the water tank fill? It should be pretty close to that.
โAug-15-2013 04:18 AM
Atlee wrote:
One other thing to check. It shouldn't be a problem for you since your rig is new, but you never know.
My new to me 2012 Koala has a strainer in the line next to the intake on the water pump. It was completely clogged. Once we cleaned it out, we had running water.
GlennLever wrote:
I'm working my way through the systems in a new to me MH. I'm only getting a very small amount of water out of the faucet and if I open another one no water. I can hear the pump running.
jbbrick wrote:
Check the valves at the water inlet setup, you may have it switched to "fill" or "city water" instead of the pump setting. Sounds like it's just trying to prime itself and can't do it because of the valve position. Don't have one of those RVs so I can't be specific. I'm assuming there is water in the fresh tank? If it was only one faucet I'd say the aerator is plugged but you say it also doesn't come out of another faucet.
โAug-15-2013 04:17 AM
โAug-14-2013 10:02 PM
Porsche or Country Coach!
โAug-14-2013 09:59 PM
โAug-14-2013 09:53 PM
โAug-14-2013 09:42 PM
โAug-14-2013 09:14 PM
โAug-14-2013 08:59 PM
