Oct-12-2013 01:42 PM
Nov-24-2013 11:11 AM
Nov-24-2013 09:31 AM
Oct-15-2013 06:42 AM
Bud
USAF Retired
Pace Arrow
Oct-14-2013 09:39 PM
Oct-14-2013 07:26 PM
Oct-14-2013 07:12 PM
Bud
USAF Retired
Pace Arrow
Oct-14-2013 06:50 PM
Current code does not allow for two wire wiring, only three wire that includes a safety ground.2011 NEC 404.4(D)(2) allows a grounding-type GFCI receptacle or a GFCI protected grounding-type receptacle to be installed on an existing 2-wire circuit.
Oct-14-2013 06:39 PM
enblethen wrote:
Some manufactuers still make no feed-thru GFCIs for rehabs of existing two wire systems. Some locales still stock these.
Oct-14-2013 03:21 PM
Oct-14-2013 03:19 PM
Bud
USAF Retired
Pace Arrow
Oct-14-2013 02:45 PM
Oct-14-2013 02:36 PM
Bob Landry wrote:stubblejumper wrote:Bob Landry wrote:enblethen wrote:
The GFCI receptacle is the same as residential.
Any GFCI you buy is going to be a "feed through", whatever is meant by that. The terminals are going to be marked Line and Load and have to be connected correctly or any outlet downstream from it will not function properly.
Not true. Line and load are the input. Usually your GFCI is the first plug on the circuit. New GFCI's will often have both "feed through" and "pass through". Feed through means on going circuits are GFCI protected. Pass through means following circuits are not GFCI protected. There are separate terminals or "push ins" on the back of the GFCI for each circuit. Read the instructions that came with your FCI carefully so that the following circuits are hooked up as required.
Where in the world did that come from?
Oct-13-2013 04:42 PM
longdog2 wrote:I wouldn't wait for checking the GFCI or the percolator, just replace the device. These devices seem to have a finite life if tripped. Tripping the receptacle's safety feature more than just a few times is usually cause for demise. If this was the original GFCI, there would be the additional concern about the quality, our friends, the RV makers, are not about quality.
Appreciate all the help. Since my RV is in storage without the ability to hook up to shore power, I will have to wait to replace the GFCI. I will double check the outlet inside the storage bay and the outside outlet (it has a cover). I guess I could also go get the percolator and bring it back to the house to check it out on a GFCI outlet here; however, I have also used the crockpot and rice cooker. The results were the same. Sometimes it continues working for many days in a row without a problem and then the next time I will try to use it, the GFCI has popped.
Oct-13-2013 01:15 PM
