Outside shower!
riley61306
I have a 2005 Alfa see ya 5th wheel. Today I was replacing the city water inlet because the check value was bad....i untwisted the old one and when I let go to turn around to grab the new one, the water line went up into (lord only knows where) and I cannot see it nor reach it to twist the new part on ????????. First off.....why would they have it like that???? And 2nd, how on earth would I get to it now??????
11 REPLIES 11
wnjj
fourthclassC wrote:
If you have to cut a piece out of a panel to access the tubing, there are some spring loaded access panel covers available that don't look too bad.
Might not look so good in the shower wall, though. ๐Ÿ˜‰
fourthclassC
ppine
Go at it from inside. Should be easy.
way2roll
Navigator
Navigator
riley61306 wrote:
Valhalla....thatโ€™s my fear ??
DFord.....heck I might just buy one of those cause it looks cool to have anyway ??
I have one, works great. It works with an app on your phone. I've used it for all kinds of stuff including chasing down plumbing issues. Saves a lot of time and money from not having to put holes in the wall.
Jeff - 2023 FR Sunseeker 2400B MBS
riley61306
valhalla360
Nomad III
Nomad III
They probably installed it and then installed the interior walls and shower stall.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
DFord
If all else fails, I see Amazon has a borescope that projects an image on your cellphone for $20 with a 4.9 rating. At that price and rating, I may have to add one to my toolbox.
https://www.amazon.com/ILIHOME-Endoscope-Semi-Rigid-Inspection-Waterproof/dp/B081ZZS13W
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
riley61306
Iโ€™ll try in the morning to stick my phone up in the hole a take a pic! I didnโ€™t even think about trying that! Thanks
riley61306
On the other side of the wall there is an access panel under the pantry but I didnโ€™t see the water line in it. Behind that panel is the shower. It seems like itโ€™s in between that panel and the shower wall with no access to it.. ??
Dutch_12078
If there's enough room, stick your smartphone in the hole and take a picture to see if you can locate the pipe.
Dutch
2001 GBM Landau 34' Class A
ScottG
Is there any kind of panel on the inside of the RV that you can remove to access the connection? Often it just blends in but has a few screws holding a hidden "door" someplace. Or maybe it's behind something - whats on the other side of the wall?
