โSep-30-2013 06:38 PM
โOct-03-2013 06:49 PM
he circuit protector=20amp might cause problems trying to push higher current thru it plus the regular 120 plug could create some headache.
โOct-03-2013 09:45 AM
nieforth wrote:It never has on mine. And I've run both the a/c and the MW at the same time! (but not long)
The circuit protector=20amp might cause problems trying to push higher current thru it
โOct-03-2013 09:40 AM
โOct-03-2013 09:11 AM
msiminoff wrote:Yes, if you are careless enough to not plug them both in before starting either generator.
However, as others have mentioned there is the very real risk of an electric shock if there is AC power at an exposed male plug.
โOct-03-2013 09:00 AM
nieforth wrote:
Lots of discussion on paralleling 2-2000i Honda generators together using the 120 volt outlets on the unit.
โOct-02-2013 10:26 PM
โOct-02-2013 10:07 PM
โOct-01-2013 07:55 AM
โSep-30-2013 07:34 PM
โSep-30-2013 07:06 PM
