Aug-01-2021 11:34 AM
Aug-02-2021 07:41 AM
Aug-02-2021 07:34 AM
Aug-02-2021 01:56 AM
SHRED wrote:
Any recommendations for a quality VOM? I'm tired of cheap junky ones.
Aug-01-2021 04:37 PM
Aug-01-2021 03:39 PM
CA Traveler wrote:
FYI Once you disconnect and reconnect the battery electrical resets may occur and you no longer have the drain perhaps until driving and turning off the car. That is just one reason why a clampon ammeter is so useful.
Sounds like you meter is not working.
Aug-01-2021 03:33 PM
wa8yxm wrote:
Sounds like either the VOM is bad or the operator (you) is... Yup that can happen.. I have multiple VOMS and sometimes get confused as to how they work. (No two alike type thing)
Suggestion is a Jump Starter. they make two types (I of course have one of each) one is a Lead Acid (AGM) battery in a big HEAVY box. about 25 Amp horus usually with battery leads Some of these have air compressors, work lights and other features.. NOTE when hooking up it is suggested the NEGATIVE (Black) wire NOT go to the battery but rather the block or other unpainted metal part (This is for US cars with Negative ground.. If by some strange chance your car is positive ground that's the RED wire).
The other is a LI tupe... way lighter. 10 AH but about the same Kick Start power.
I use, or rather used, the big one as a "Portable car" for powering 12 volt stuff that plugs into the accessory outlet.
Aug-01-2021 02:49 PM
Aug-01-2021 02:45 PM
Aug-01-2021 01:18 PM
It isn't your cheap junky meter.
It is how you are using it.
10A setting you must use the input marked 10A.
On 10A setting you will have a very low current resolution of .1A at a time which will not reveal very low current draws.
Your DVM should have a MA (Milliamp) setting (may look like 1000 (1000 is 1A), 100, 10) which has a higher resolution. That setting will use your normal DVM "Volt/resistance" input lead.
Choose the highest range on the MA setting then switch down..
Have to very careful when using the MA setting as it is to smoke the meter..
Aug-01-2021 01:00 PM
SHRED wrote:
Is the allowable amp draw about 0.3 amps?
thanks
Aug-01-2021 12:52 PM
2oldman wrote:
How old is the battery?
Aug-01-2021 12:49 PM
SHRED wrote:Yestime2roll wrote:The VOM still reads voltage.
Check the 10a fuse in the meter.
Would that still be possible with a blown fuse?
Aug-01-2021 12:31 PM
Aug-01-2021 12:30 PM
