Patching a PPO rubber roof?
precioustime
A small diameter area about 6" needs patching on a rubber roof.I heard of Dicor Patch. Any good? Will it be noticeable? Will it last long? An alternative would be to replace the complete roof with a new rubber material but that is very expensive. And disadvantages to that procedure? The area that needs covering is very small.
Moved to Tech Issues forum from DIY.
9 REPLIES 9
beemerphile1
dbbls wrote:
TPO is EPDM material with a coating on to prevent black streaks.
Totally incorrect according to the Whole Building Design Guide which is the resource used by architects.
"Thermoplastic polyolefin (TPO)
TPO is the latest thermoplastic membrane introduced into the marketplace....It is formulated from polypropylene, polyethylene or other olefinic materials...."
"Ethylene propylene diene monomer or terpolymer (EPDM):
EPDM is a synthetic rubber sheet...."
TPO seams are heat welded, EPDM seams are taped or glued. They are different materials. TPO is more expensive and a superior product.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
RJsfishin
I run a rubber roof for years, just carried a 4" roll of eternabond w/ me.
IMO, there would never be a reason to replace a rubber roof,....not as long as a 12" and 24" roll of eternabond is available.
Rich
dbbls
beemerphile1 wrote:
Eternabond tape will take care of it.
What is a PPO rubber roof? There is TPO which is more like vinyl and EPDM which is rubber.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
64thunderbolt
eternabond, done deal
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
TurnThePage
Another vote for Eternabond. Great stuff.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
beemerphile1
dbbls
I put a dicor patch on the roof in 2004. It was still on and in good shape in 2012 when I traded the trailer.
1492
Moderator
Moderator
Moved from Forum Technical Support
bearsfolks
I would suggest Eternabond tape. Once its stuck it wont come loose.
2005 Silverado 2500 HD, Duramax/Allison. Hypermax E-con Max Energy programmer, Banks intake and exhaust.
2002 Cardinal 28RK
Prodigy brake controller, Bilsteins, Ride-Rites, 5th. Airborne pinbox.
Dave, Kathy and the dogs
