โApr-11-2018 02:42 PM
โApr-18-2018 01:07 PM
westend wrote:
...The fridge draws 80w, operating, and probably 5-7 Amps at start up. ...
โApr-17-2018 11:00 AM
as for venting for gasses.Yes, hydrogen is lighter than the atmosphere. FLA Batteries produce a small amount of hydrogen when charging. That could be when on the road and the tow vehicle's alternator is providing power or from RV mounted solar charging. Since there is very little volume of hydrogen produced, a large vent hose isn't needed. It does need to be at the top of the enclosure and a make-up hole installed close to the bottom of the enclosure for proper air flow.
is this gas lighter than breathing air? thinking hendenburg.
as where my batt's live it is mostly open under them . so a upper vent is worth it.
โApr-17-2018 10:49 AM
โApr-17-2018 10:21 AM
โApr-16-2018 08:00 PM
โApr-16-2018 06:46 AM
Bear N Honeys wrote:
I hope I am doing this right. I see things you all post but have a question. How do I ask a particular person for more information on their answer to another post? For example above Gdetrailer mentions Tripplite inverter. I would like more info.
Thanks
John
โApr-15-2018 07:03 PM
โApr-15-2018 06:38 PM
โApr-13-2018 11:37 AM
RoyB wrote:
Just keep in mind that a 2000WATT Power Inverter can pull between 160-180DC Amps from your battery bank when fully loaded. This will require HD cabling and more than one standard size batteries. You also want to not plan on using your standard truck alternator in a situation like this when charging... This is alot of DC Amps being drawn...Roy Ken
โApr-13-2018 04:34 AM
โApr-12-2018 01:51 PM
โApr-12-2018 12:05 PM
You also should follow good installation advice and NOT install the Power Inverter in the same location as the Wet Cell Battery bank. The batteries can emit explosive fumes when being charged and a small spark from DC switching action could set off an explosion... Probably never happen but it could...
Just saying....
Roy Ken
โApr-12-2018 09:27 AM
โApr-12-2018 07:21 AM
