Portable battery charger. What do you carry?
McKenziek
I've had many over the years but most are cheap and don't last long. I'm looking for a good portable 12 volt Smart charger that can desulfate and get my batteries to full charge if needed.
What do you carry in your RV tool box?
2005 Monaco Diplomat
56 REPLIES 56
BFL13
The Scouts say, "Be prepared." Some of you guys must have accidentally joined the Girl Guides instead! (At least you can make good cookies as long as you have shore power) ๐Ÿ™‚
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
bka0721
KJINTF wrote:
Why do you good folks carry a portable charger?
Help me out what am I missing?
Is it that you do not have an
On board hard wired converter
Or a capable solar system
or the engine alternator is not connected to the battery bank
Very good question.
Full disclosure, I use a Black & Decker too and my convertor is disconnected.
My Solar system is very capable, but when your demand use is 150 โ€“ 200AmpH a day and you only have 900w, you still carry a separate charger. Redundancy is an important factor when you boondock 98% of the time and havenโ€™t plugged into electricity for a few years. What you might not be considering is the days when you have cloudy weather, or the outside temperatures drop and your S.O.C. is low, due to no fault of your Solar (batteries lose % capacity faster below 70?F). So those that use their Solar/Battery Banks in the winter season, need supplemental charging when their AmpH demand exceeds their daily solar harvesting. I liken my Battery bank (1,168AmpH) to a checking account. If I am withdrawing a sizable amount of cash (amps) every day and I am hoping to have a daily deposit equal or greater than my withdrawals, I am good. If I have a day that my withdrawals donโ€™t match, I can assume that I might withdraw less the next day and or have more deposits. But if you donโ€™t, your checking account will slowly become deleted with the daily withdrawals and deposits that are not equal. My checking account is assessed a high Fee if I allow it to drop below the Minimum Deposit I have agreed to (55%). If I drop below this minimum deposit too many times/often, my checking account could be closed without my permission (Dead Battery Cells). So yes, it is important to keep your Batteries charged up during those times when your Solar is not keeping up with your demands, due to cloudy, cold temperatures and or heavy use. A Aux Battery Charger can and does have its advantages.
Charging with an alternator? That works when your assumption meets reality and you are moving frequently and for sustained number of hours or running it. Many of us travel shorter distances, where an alternator does not function in an efficient way. Running an aux battery charger/generator is often less expensive that the operation of a Tow Vehicleโ€™s engine.
As
KJINTF wrote:
Hi mena661
Guess that's why the Paramode converter has temp compensation
Most good converters do
Just sounds easier to me to use the hard wired option rather than connect up a portable unit
One day soon when you get your 800watts of PV solar array you will leave the portable charger at home. Your solar array will easily get the Equalization done when needed and will have temp compensation
That might be a good plan, if;
You donโ€™t run into multiple days of cloudy weather.
Outside temperatures below 70?F that reduce your battery capacity.
Or camp in an area that is full of trees, as most campgrounds in the mountains are. (Funny how the majority of RV owners are looking for shade and those that are Solar Snobs, like me, are parking out in the sun.)
b
08 F550-4X4-CC-6.4L Dsl-206"WB GVWR17,950#
09 Lance 1191
1,560wSolar~10-6vGC2-1,160AmpH~Tri-Star-Two(2)60/MPPT~Xantrex 2000W
300wSolar~2-6vAGM-300AmpH~Tri-Star45/MPPT~Xantrex 1500W
16 BMW R1200GSW Adventure
16 KTM 500 EXC
06 Honda CRF450X
09 Haulmark Trlr
Rbertalotto
Most of the battery chargers I've tested , and this includes ALL from Harbor Freight and Sears will not put out 14.3V to bring a battery all the way back to full charge. The B&D as listed above is the only one.
I bought brand new Johnson Control batteries (Walmart) and simply couldn't get them to full charge. Tried my big SEARS charger/starter, tried my old SPORTMAN 10A, tried the $27 Harbor Freight, tried the 12V outlet on my Honda 2000 generator. Nothing would bring the batteries full. The B&D was ordered from Amazon and arrived last weekend. In 48 hours it had the batteries singing and my Trimetric 2025RV FINALLY reading correctly and showing proper full charge.
If you don't bring the battery back to a full charge with 14.3V you are killing your batteries slowly but surely.
The converter in my truck camper will only put out 12.7V....Terrible! All of the other chargers in my arsenal will only max out to 13.2V....Not good enough!
If you have a GEL or AGM battery this is even more critical as these batteries require a much higher charge rate than Wet batteries.
There are many, many articles on the internet about this...All riveting reading!.... ๐Ÿ™‚
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
MEXICOWANDERER
Converters don't die when you're parked in the lot at Camping World, they die in the campground in Yosemite Park or Wells Nevada, or Ennis Montana. or Marfa Texas.
Remember Kelly said Murphy was an optimist.
Bobbo
MrWizard wrote:
because things happen
who wants a ruined trip because of discharged batteries and a dead converter
this forum is full of posts about a trip saved from a dead converter or even dead alternator/regulator because of having a portable charger on hand
The only charger I have is my built in PD4655V. If it ever dies on me during a trip, I will get in my car and drive to a hardware store and buy a portable. Seems more efficient to me than carrying a portable for years "just in case."
Bobbo and Lin
pnichols
I carry a 2/10/50 charger-starter similar to the one above, but a different brand and much older.
I set it on it's 50 amp "starter" setting to charge our 200 AH AGM RV battery bank. The batteries won't absorb anywhere near 50 amps from this charger so leaving the charger on this setting doesn't cause it to trip it's circuit breaker, even after a couple of hours on this range. However, using the charger's 50 amp starter range does provide more current to the batteries than with the charger set on it's 10 amp range.
We don't clip our charger directly to the battery terminals. We clip it to the heavy duty cable connectors on the built-in generator where the cables coming over from the RV battery bank connect to the built-in generator for starting of the generator. This is a much easier way to attach the charger than opening up the RV's battery compartment.
2005 E450 Itasca 24V Class C
Bumpyroad
pianotuna wrote:
Hi,
I like a belt and suspenders so I carry the aforementioned Vector and a "dumb" charger from Harbor Freight. So far, I've only used them to try to help others.
Battery Charger/Engine Starter, 10/2/50
Mine is a bit earlier model:
I got one of those for $27 as I recall with a coupon.
bumpy
pianotuna
Nomad III
Nomad III
Hi,
Regards, Don
hershey
Because many of us have a Xantrex converter and because they are so darn unreliable you have to carry a spare.
hershey - albuquerque, nm
Someday Finally Got Here
My wife does all the driving - I just get to hold the steering wheel.
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
mena661
KJ, the only converter that I'm aware of with temp comp is the Paramode. None of the others have that. I liked that about the Paramode but I didn't like its low charge voltage. You have to step up to the much more expensive inverter/chargers to get temp comp. That's not an option for a lot of people because of their prices.
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
KJINTF
Hi mena661
mena661
The B&D1093 portable has a far better charge algorithm than any of the crappy converters on the market plus it's temp compensated and built in equalizing. For me the temp compensation comes in handy on the really hot days.
Dave_H_M
It has been a habit for me i guess. Years ago my converter shot craps out in the small town land. I got a 6 amp charger from Walley's, finished out the season on it, repaired the RV, and threw the charger in the basement. I think it is time to unload and tyhrow that thing in the barn - been years. :W
SCClockDr
No portable charger in our stuff. I got jumper cables though.
George & Cathy
08 Titanium 28E33SA, XM, Honda EU 3000is, Trimetric, RotoChocks, LP Reg. Mod, 2 Gal Accum., WiFiRanger GO2/Mobile
04 Ram 3500 5.9 DRW, PAC PRXB E/B, 4" MBRP SS Exhaust, Gauges, Aux Tank/box, BrakeSmart.
ETCS (ss) USN Ret
