Power Gear leveler issue
SanDiegoScubaDi
I have a 2005 Jayco Seneca 35GS, which has the stock PG auto levelers. Everything is working fine with them, however when I retrieve them the beeping that tells you they are still down just keeps beeping. The jacks are up, but the sensor thinks otherwise. I suspect the sensor needs to be adjusted but not sure where to start on that.
Any thoughts from the forum?
Derek, Lykke...
and Kane and Sweet Pea our Llewellin Setters who really are in command of our rig!
2011 Jeep Grand Cherokee
7 REPLIES 7
John_Wayne
If you have never changed the fluid now would be a good time to do it, replace with synthetic merconV
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Corkey05
SanDiegoScubaDiver wrote:
Thank you for the great feedback. Looks like I check the fluid level and the hoses for leaks. Sounds fun...!
With luck you may not have a leak. It may have finally purged an air bubble trapped in the system. I added to my 2005 a couple of times but never found a leak ... after the second time it never needed fluid again.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
SanDiegoScubaDi
Derek, Lykke...
jerseyjim
ATF is the fluid of choice, yes. Last year, coming home from a trip, the alarm sounded. First time in 15 years. Yes, fluid was low. Added some. Next trip, coming home, same thing. THIS time, noticed (red) oil on the grass. One of the hoses (passenger side front) had a pin hole in it. Took the hose to a hydraulic shop, new one made. New fittings included (7 feet long) Installed it, end of problem.
2 weeks after that...another hose leak. That one was 33 feet long. Some fun getting that one out from the channel frame.....LOL !! That one had a chafe that wore thru.
doxiemom11
Ours do that with low fluid level and they don't have to be very low for the alarm to sound. Most use Automatic Transmission Fluid. Be sure what yours uses before putting any fluid in.
MrWizard
Moderator
Moderator
moved from technology corner
I can explain it to you.
1997 F53 Bounder 36s
Corkey05
Check your fluid level. It's not unusual for the system to purge air over time leaving the fluid level just low enough to trigger the alarm.
FMCA F374292
