pro 16 slider hitch
grich
I have a pro 16 slider hitch and having a hard time
getting it to slide. The bar to get it to slide when
hooked up to 5th wheel will not move to maneuver.
when unhooked will work ok. How level does the trailer
have to be. Are there any tricks to getting this to work.
thank for any support
3 REPLIES 3
Charlie_D_
slowly pull forward when engaging either way. The bang of stopping will scare you.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
DonCopenha
Manual says to lift weight of trailer up with front jacks first. VERY inconvenient but works.
2013 Heartland Torque 325SS
2007 Dodge Megacab 3500 CTD DRW
Gauges, No muffler
Nicholsfamily05
When we first got our trailer we were practicing in a parking lot and it worked fine.
Got it home and figured let's try backing it in with it and see how it does. Nope wouldn't work once on the rough/ grass/ dirt.
Trailer was pretty level.
Since then we have never used it again. Haven't needed too.
Our friend said he has had the same issue.
Once on a hard packed surface seems to work.
Sorry no advice on how to make it work, been over two years and never needed it.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
