โMay-19-2013 11:00 AM
โMay-26-2013 10:55 AM
red31 wrote:
A liquid level gauge should rise and fall with the temperature.
approx. 1% change in volume per 10F
http://www.propane101.com/propanevolumecorrection.htm
โMay-26-2013 08:28 AM
โMay-26-2013 07:44 AM
โMay-26-2013 07:41 AM
Dusty R wrote:
We have a SeeLevel monitor panel. When the propane is at 80% the panel shows 100% which means the propane capacity is full.
26 March Arrived home in Michigan from Florida.
9 April panel read 59%
14 April " " 56% I turn off main valve on tank firmly
23 April " " 51%
29 April " " 49%
6 May " " 45%
14 May " " 41%
19 May " " 41%
25 May " " 42%
Could these different % readings be because of increasing ambient temperature?
It got up into the 80's for a couple of days then down into the 50's for a couple.
The mh is stored in an unheated, uninsulated pole barn.
Dusty
โMay-26-2013 07:35 AM
โMay-26-2013 07:24 AM
โMay-20-2013 10:10 AM
โMay-20-2013 04:35 AM
โMay-19-2013 03:17 PM
Dusty R wrote:
It's not a pressure gauge, it's a level gauge. In order for pressure to increase the liquid needs to vaporize, which heat will cause, more vapor less liquid, thus lower level.
I did turn the valve off firmly, still level went down, until this week.
I've had one in the past where the valve stem packing on that valve leaked.
Dusty
โMay-19-2013 02:12 PM
โMay-19-2013 01:52 PM
โMay-19-2013 12:20 PM
โMay-19-2013 12:19 PM
โMay-19-2013 11:13 AM
Dusty R wrote:
How much does the level of propane, in a tank, change with the change of ambient temperature? As the weather has warmed the level in our tank has gone down about 2 to 3% each week in the past couple of months. About a month ago I closed the valve on the tank, thinking there might be a small leak in the line, and the level still continued to go down. It's kind of hard to believe the tank leaks. A leak that small is hard to find.Dusty
