Propane line plug
swimmer_spe
I will be pulling out the fridge in my trailer. Eventually, another will take it's place. For now, I need to plug it.
What size of plug would I need?
5 REPLIES 5
wa8yxm
Take solenoid valve fitting to Hardware. they will match it for you.
ScottG
swimmer_spe
bobsallyh wrote:
Should be a brass 3/8" male plug flare fitting.
Thank you. For some reason I was thinking 3/4''
DFord
Most refrigerators I've seen are connected with a 3/8" copper line. Get a 3/8" flare brass plug at an autoparts store and that should work for you.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
bobsallyh
