Propane smell after filling
jpratt2
Hi all: We're presently on a trip though Idaho and Utah. I had the propane topped up at an RV park and now several hours later there's an odor of propane on the outside near the tank despite having driven 100 mi. No smell inside.
I've noticed this before after fill-ups. Is this common?
Also, I have to admit being rushed during the full-up and (like an idiot) did not shut off the tank main valve first. Could this be an issue?
We're avoiding using any propane appliances until I figure this out.
Thanks in advance.
14 REPLIES 14
RCMAN46
eHoefler wrote:
Old-Biscuit wrote:
Vendor opened bleed vlave when filling...vapor came out then when reaching FULL (80% level) LIQUID spewed out. Vendor closes bleed valve/stops filling
BUT liquid propane (Mercaptan) residue is ON TANK......so you smell it for a while.
What he said
X2 but it is pertinent to make sure the bleeder and main valves are closed.
Do not over tighten them especially the main valve. Had a propane jocky do that on one of my tanks which ruined the valve and made tank useless.
wa8yxm
First Propane has no odor. they add a chemical to it to make it stinky for safety reasons (Essence of Skunk as I recall).
When they fill the tank they open the Visual OverFill indicator Valve.. Sometimes called a "Spitter" valve for short.. Now I've read many posts that have me shaking my head about what this valve is for (No truth to 'em at all) but here is what is is for.
The valve is at the 80% full point.. Propane. under the kind of pressure they pump. is a liquid.. It evaporates at nearly -40 when the pressure is reduced.
Thus about an hour ago as the Pump Jockey filled my tank it vented GAS. not AIR but Propane Gas.. Yes it is flammable.. But it was GAS. Then suddenly it started spitting liquid, which instantly vaporised and condensed water making white FOG. at this point the Pump Jockey shut off the fill valve, shut the spitter valve and unhooked. Some additional LIQUID escaped when he disconnected.
This means some of the Chemical additive got on things around the tank and it will take a bit to evaporate So long as the odor fades.. You are good.. Increases are NOT GOOD.
jpratt2
Update...it's a leaking tank...pinholes from rust. Having it drained at a propane plant now. Check your tanks for corrosion everyone! Thanks for all your suggestions!
Dennis12
X2 Old Biscuit
Dennis Hoppert
eHoefler
What he said
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Old-Biscuit
Fulltimers
Use soapy water to check for leaks. If no leaks found then it is just residual smell. I always get propane smell after a fill up but it goes away soon.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
MEXICOWANDERER
LPG odorant concentrates in refinery processing lube oil. One day in Lee Vining, CA. I emptied the oil out of a pot that saw a lot of use in Mexico. Those were the days when the dump would magically catch fire once a week. The oil was dumped on cardboard. Not a drop hit the earth.
Move kleige lights and boom mikes...
Fire department responds to emergency. "Massive LPG leak at disposal site"
Methyl Ethyl Mercaptans hold the Guinness Book record for the smelliest stuff on earth.
So...when leak testing is inconclusive check for oil stains near the filler and 10% valve. Clean with smelly carburetor cleaner followed by alcohol.
jpratt2
Yes...on-board horizontal tank. Thanks...I tightened it a bit more...hopefully that's the issue.
nineoaks2004
darsben1 wrote:
Then my bet is the guy who filled the tank did not close the bleed valve completely
X 2 also happens on the 20 LB tanks too.
By the time you learn the rules of life
You're to old to play the game
darsben1
Traveling with my best friend, my wife in a 1990 Southwind
mobeewan
His profile shows he has a 29' Bigfoot class C.
RJsfishin
Maybe got filled too full, and slowly bleeding off as the temperature rises ?
Like said above, make sure the bleeder valve is off tight.
Remember, a tiny bit of that smell goes a long ways.
Rich
darsben1
Permanent tank or refillable cylinder
Could the filler not have shut the bleed valve completely
