โApr-14-2014 06:59 AM
โApr-16-2014 07:54 AM
FloridaFlyer86 wrote:
I do not, for now I think I can do without the 3 stage operation since I want to only do bulk and absorption with the DLS-45 and finish the absorption and float with the PV and SS controller.
โApr-15-2014 06:20 PM
โApr-15-2014 01:04 PM
โApr-15-2014 11:56 AM
JiminDenver wrote:
The OP hasn't mentioned just how far down his batteries were discharged.
mena661 wrote:
Do you have the IQ4 module with your Iota? You need that for 3 stage charging.
โApr-15-2014 11:22 AM
โApr-15-2014 10:52 AM
โApr-15-2014 10:29 AM
โApr-14-2014 12:09 PM
โApr-14-2014 10:37 AM
FloridaFlyer86 wrote:NinerBikes wrote:
Rough rule of thumb, for every AH you have at 12V, you need at least 1 to 1.5 watts of solar panel to charge it. Since you have 440AH in storage capacity in your batteries, you'll need about 440 to 660 watts of solar panel to get the job done.
That's about what I want to have, and hopefully will make it happen soon. Should have mentioned the PV panel is not the only charging source, I have been using my Honda 2000 gen with the stock converter but of course the crappy converter is only giving me 13.5 volts so is also not doing a good job of charging either. I have an Iota DLS-45 charger arriving UPS this afternoon, should have ordered it before getting the new batteries but I wasnโt sure if it would meet my needs or if I would need a fancier Xantrex or other charger. After research it looks like the DLS-45 feature of having a jumper wire to force 14.2 volts should be fine for morning and evening charges with a generator.full_mosey wrote:
I have experience with the SS gen 2 controllers.
Yours is working fine. It is a two stage charger(no 3rd float stage). During Stage-1,bulk, it charges at the panel ISC depending on the panel tilt. The Volts then increase to 14.4 where stage-2, PWM, kicks in and current is tapered down. Your solar panel is not supplying enough daily Amps to raise your battery bank to 14.4V and is not reaching stage-2.
The 12.5 resting Volts is too low and proves that the bank is not being recharged daily. This is an undercharge situation that will result in sulphation and ruin the bank.
Consult the mfgrs manual.
HTH;
John
That makes sense, I see now that I didnโt understand the SS operationโฆ so I havenโt even been getting into PWM mode. That would explain why I did see 14.4V with the older, smaller battery bank. Hopefully after installing the DLS-45 and spending some time charging at 14.2V I can use the PV system as I intended, to top off charge after bulk charging with the gen. Iโve only had the batteries a little over a week and been careful not to discharge them too low, according to the TM-2025 I havenโt gone below 75% and that was only a couple times. So hopefully I havenโt done irreparable damage!
โApr-14-2014 10:17 AM
HTH;
John
โApr-14-2014 09:23 AM
โApr-14-2014 09:07 AM
Ok solar gurus - I am experiencing low voltage with my PV solar system. The charging voltage will not go above 12.8V. I'm using a Morningstar SS-6L-12V SunSaver controller (2nd gen) with 4 new Crown 6V 220 AH batteries wired series/parallel for a 440 AH 12V system, and a single 95 watt PV panel (astroenergy). The measured open circuit voltage from the panel is 20.3V. The SS-6L-12V should be charging at 14.4 volts for flooded batteries. The green charging light is on. Iโm using a TriMetric TM-2025-RV battery monitor and I do get positive current flow (5A) but Iโm going to end up stratifying my batteries if I donโt get the voltage up. I also have measured the voltage at the terminals of the controller and also see 12.8V there. (at rest battery voltage is 12.5V.) This is a new system (so all connections are new and clean, with dielectric grease and proper torque) but the components have been used beforeโฆ over a year ago so my memory is hazy but Iโm pretty sure I saw 14.4V before. Iโm not too concerned about any wiring being undersized, I went overkill to avoid that possibility.
So I have an email in to Morningstar but I have no idea how long they might take to respondโฆ and I might just have something stupid going on, unrelated to the controller. Any help is appreciated, hopefully I havenโt left anything out.
โApr-14-2014 08:39 AM
lasttruck wrote:
Not one answer about the voltage.
โApr-14-2014 08:34 AM
