โJul-13-2021 06:03 PM
โJul-16-2021 03:41 PM
Old-Biscuit wrote:
Yours could be NPT or Inverted Flare (check which in the LINK above)
If old hoses screw directly into REG body then NPT
If old hoses screw into a brass adapter on REG then Inverted Flare
Yellow Gas Tape on NPT...not on Inverted Flare
Tighten until you feel good resistance ....
No washers used.
โJul-15-2021 07:53 PM
rvshrinker wrote:
what is the RIGHT direction?
โJul-15-2021 06:32 PM
rvshrinker wrote:The correct way should wrap the tape around as you are turning in the direction of tightening the male fitting. You will be Turning to the right as you have a right hand thread.
โJul-15-2021 06:24 PM
โJul-15-2021 10:15 AM
โJul-15-2021 08:57 AM
StirCrazy wrote:rvshrinker wrote:
thank you that is so helpful!
This article suggests yellow tape is the preferred sealing method and adequate:
https://www.oasisngv.com/vdb/document/1179
actualy it doesnt, it says it is more conventiant for the worker to use as it is easier to carry , doesnt have a shelf life, and has no cure time. if you dont wrap it properly it can be the worst one you'll use.
I used to work for a gas company when I was a young lad and we would have been fired for using tape instead of liquid sealers. if you notice when the rv's come from the factory they use a liquid sealant also. the choice of liquid sealants is just as important though, you want to get a non hardining one, so it sets up but doesnt harden like a rock.
Steve
โJul-15-2021 05:39 AM
โJul-14-2021 10:14 PM
โJul-14-2021 08:39 PM
rvshrinker wrote:That is fine too.
Translation: why canโt I use the ones I bought and attach directly to regulator using yellow tape? Will that not work?
โJul-14-2021 08:33 PM
Bud
USAF Retired
Pace Arrow
โJul-14-2021 08:13 PM
โJul-14-2021 02:20 PM
rvshrinker wrote:
Alright, the old ones I removed seem to have a small more narrow male end, which is inserted into a brass adapter, which I removed when I took the pigtails off the regulator.
However, the new replacement pigtails seem to have an integrated brass piece so that it would attach directly to the regulator, with no additional adapter needed.
This is what I bought
https://www.amazon.com/gp/product/B083WGZYNZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
โJul-14-2021 11:36 AM
Old-Biscuit wrote:
"Alright, the old ones I removed seem to have a small more narrow male end, which is inserted into a brass adapter, which I removed ...."
Inverted flare......
Did you open the Link I posted to types of fittings?
Scroll down and look/read about #3
Did you crack the regulator by overtightening??
โJul-14-2021 09:26 AM
