โJul-21-2019 03:52 PM
โJul-21-2019 06:16 PM
MitchF150 wrote:
Best to check your voltage when plugged into whatever configuration you have and go from there...
If you plug in and then turn on the AC get a volt meter and plug into any other 120v outlet in the rig and read it's voltage output..
If it's much below 108v, then you might need to consider some other power source, but for a short time, and if it does not trip the 20a breaker then you are probably "ok"...
No way to say for sure one way or the other, but you can also feel the cords and if they are really warm to the touch, then maybe you are drawing too much...
Good luck!
Mitch
โJul-21-2019 06:07 PM
โJul-21-2019 06:05 PM
โJul-21-2019 05:51 PM
โJul-21-2019 05:49 PM
โJul-21-2019 05:36 PM
โJul-21-2019 05:30 PM
โJul-21-2019 05:11 PM
โJul-21-2019 04:29 PM
etrippe wrote:rk911 wrote:
be sure to turn off the charger portion of the charger/converter else it trips your circuit. i know from experience.
How do I do that?
โJul-21-2019 04:17 PM
โJul-21-2019 04:12 PM
โJul-21-2019 04:11 PM
โJul-21-2019 04:09 PM
โJul-21-2019 04:04 PM
โJul-21-2019 04:01 PM
