Running light don't work-2010 Class C Winnebago Ford 450
Bwairman
Seems my Runnign light don't work, tryied the fuzzes in the cab, no issues there. Vehicle lights all work, Head, turn 4 ways, brake, just no running light anywhere on the couch its self. What could be the issue?
6 REPLIES 6
Bwairman
Removed every fuze and found the one that was blown, it was the trailer backup tial power. Never heard of a trailer haing a backup lights. But it fixed not. Oh it was under the hoor fuze box area, slot 58. Hope this helps someone else one day! THanks for all your comments and help.
Ray___June
You might also check to see if the manufacturer installed a relay to activate the running lights. The headlight switch was originally designed to run headlights, side markers and taillights on the vehicle, not 8-12 more running lights.
Too much amperage through the light switch was a common problem for RV's for many years until they started using relays.
Sold the house, retired, and full timing. 15 years of dreams come true!
2015 Itasca 33C, Black Garnet
2013 Honda CRV EXL toad
Roadmaster Sterling all terrain tow bar
Roadmaster Tow Shield
Roadmaster Guardian
SMI "Stay-in-Play" Brake system
ISL "Toad Charge"
Beverley_Ken
Here is the link toWinnebago wiring, There are Ford fuse blocks under the hood as well as under the dash, if a fuse most likely Ford, but why.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
j-d
You can get wiring diagrams from the Winnebago site. Just as a tip, some coach builders connect the house body (stop, turn, running) lights up to "trailer" wiring harness of the chassis. So check that circuit and fuses too.
Bwairman
It is a Winnebago Motorhome, 2009 Ford F450 frame. All lights work, just not the running likes. Have checked every fuse in the whole system.
DrewE
Is this a trailer or a motorhome or a truck camper?
Regardless, you have a bad or broken connection somewhere, or a blown fuse that you haven't checked. It could be a ground connection or a power connection. If it's a trailer or truck camper, the obvious first place to start looking is at the connections between the truck and the RV. If it's a motorhome, there might be a good deal of hunting around to do to find the problem; if you can get a wiring diagram, especially one that shows the wire routing, that might be very handy.
For motorhomes, occasionally they do odd things like wire the running or other lights to the trailer light circuits of the chassis.
