RV all 4 hydraulic jacks are stuck in the up position.
jsevigny0110
RV all 4 hydraulic jacks are stuck in the up position. My emergency brakes are on, and the Control panel lights up and nothing else work, jacks wont extend. We have checked all the fuses and can't find a way to release the jacks. This is a 99 Fleetwood Bounder, 34D. Any suggestions are welcome.
Henry
7 REPLIES 7
wilanddij
Trans in Park? Mine won't work if its not.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Ford C-Max/Blue Ox
"We have met the enemy, and he is us" Pogo
sch911
If his jack control panel is lighting up his battery is connected. If you cannot hear the hydraulic pump running it's likely the issue...
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
TucsonJim
Check your battery disconnect switch to see if it's on or off.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
newman_fulltime
plug it in sounds like your batt diconnect has failed
Pepperoni
Is there a hydraulic reservoir? Even with a working pump, you need fluid.
MrWizard
Moderator
Moderator
you need someone outside listening for the Hydraulic pump
either the control is not working, or you have no power to the pump
I can explain it to you.
1997 F53 Bounder 36s
midnightsadie
just for fun, take brakes off move rv a few feet and try again,, don,t no a thing about them, but its a start. sounds like a safety switch is not engaged.
