Been having some issues , I have 2010 Ford F150 with the factory brake controller, last 2 time out got a wiring fault warning light, came up while towing and not while braking, stopped and unplugged connector and hooked back up and all seemed well, last trip it did it again and could find no problem, then when I would come to a stop (sometimes) the brakes would surge on and off and when u used the lever it was a very weak brake and sometimes hardly any brake.Warning light would say Trailer disconnected. Put a new 7 pin connector on RV and tested this morning. As soon as I got on road I pushed the lever over and had a strong very good brake and then after a few times it began to get weaker and finally I had to max out the setting to 10 and brakes did get better but still not enough, I have always used a 6.5 setting on my controller. Just wondering if any of you guys have had something like this and might point me in the right direction. All 4 RV hubs were warm/hot but not over hot when I got home and the breaks have been adjusted about 400 miles back. I have made an appointment with Ford on Monday but thought I would run it past you guys. Any ideas? Thanks ED
2012 Primetime Tracer 2640 RLS
2010 Ford F Super Cab
5.4 Engine, 3.56 Gear
Factory Tow Package
Equilizer Hitch
Wife and Myself
No Cats or Dogs
