โJul-01-2019 08:03 AM
โJul-10-2019 07:19 AM
โJul-02-2019 05:44 AM
โJul-01-2019 03:44 PM
โJul-01-2019 02:45 PM
โJul-01-2019 02:03 PM
โJul-01-2019 02:00 PM
ksg5000 wrote:
The swing arm of the motor which connects to the step is held in place with a round metal bar which has a cotter pin on the end .. remove the cotter pin and bar and the step can be moved manually. Sometimes rapping the motor will resolve problem with dead spot on the motor.
โJul-01-2019 01:34 PM
โJul-01-2019 09:52 AM
dougrainer wrote:
That wire is NOT connected to anything. It is for the OEM optional wall switch control for the step light. Odds are the motor has a dead spot. Open and close the door with the engine running. IF the under amber step light goes ON and OFF when opening and closing the door. the wiring and control are OK, You have a bad motor. Doug
โJul-01-2019 09:39 AM
โJul-01-2019 09:33 AM
โJul-01-2019 09:08 AM
โJul-01-2019 08:52 AM
DFord wrote:
More info needed to give a good answer. Does the step try to move at all? Can you hear the motor trying to move the step?
Push comes to shove, you'll need to get under the step and remove the cotter key on the linkage so the step will move and then push it in and tie them up with a rope or bungie cord.
โJul-01-2019 08:31 AM
