โFeb-17-2015 10:10 AM
โFeb-18-2015 03:41 PM
โFeb-18-2015 02:53 PM
jmckelvy wrote:Hoppypoppy wrote:
Please forgive my ignorance, but I am an electrical illiterate. I went back to the 5er and tried all the suggestions I had received at that point. More came in later, and I hope to go back again today. (little under the weather) My latest question.....is it possible, the ground wire in the power cord is itself grounded to the pin box itself? This may be the ultimate in stupid questions, but I want to eliminate all possibilities before I tear into the light fixture itself. One of the problems I am having in locating a ground wire is, the trlr is an All Season so no access from underneath. Thanks again for your help and patience.
The three posts prior to yours are the most accurate. This problem is not related to your 7-pin connector given the symptoms you report. It appears you have a single bulb system. The only things common to the tail, brake and turn lights are the bulb itself, the socket with the ground (common) connection and the ground wire to wherever it connects to the ground for the rest of the lights that do work.
Start by removing the bulb and ensure a good clean connection to the socket. Make sure you have a good bulb. Let us know what you find.
โFeb-18-2015 11:38 AM
Hoppypoppy wrote:Yes that is possible. Easy to check continuity from the 7-pin ground terminal to frame. Does not matter where it connects just so that it does.
โFeb-18-2015 09:34 AM
โFeb-18-2015 08:48 AM
โFeb-17-2015 01:59 PM
Hoppypoppy wrote:
Brought my 2002 Cardinal home from storage last Fri. Checked lights - everything fine. 5er sat in front of my home til this morning. (Tues) Hooked it up, ready to go, no tail, brake or turn signal lights on right side only. Left side fine. First thought was a ground issue. Now the dumb question.....is the only ground on these rigs the ground included in the power plug to tow vehicle? Any other suggestions? Thanks all.
โFeb-17-2015 01:33 PM
โFeb-17-2015 01:26 PM
โFeb-17-2015 12:38 PM
โFeb-17-2015 12:22 PM
โFeb-17-2015 12:04 PM
โFeb-17-2015 11:03 AM
โFeb-17-2015 10:57 AM
โFeb-17-2015 10:49 AM
โFeb-17-2015 10:47 AM
