Dec-20-2017 08:28 AM
Dec-21-2017 05:53 AM
Dec-21-2017 05:47 AM
wa8yxm wrote:
The answer is YES it is safe to splice the wires provided it is done properly.
It is ALWAYS safe to splice wires provided they are not "hot" (that is energized) when you splice them and do it properly.
Use a linesman type splice, not a rat tail and if the splice is exposed to weather use marine grade heat shrink (Get it at a marina) to seal the splice.
note many eo this some put it in the fuel pump lead, some in the starter lead.
Dec-21-2017 04:24 AM
Dec-20-2017 11:56 PM
Dec-20-2017 02:09 PM
Dec-20-2017 12:45 PM
Dec-20-2017 12:37 PM
Dec-20-2017 12:25 PM
Dec-20-2017 11:33 AM
Dec-20-2017 11:20 AM
Dec-20-2017 10:37 AM
Dec-20-2017 09:50 AM
azrving wrote:
There is probably a relay for the fuel pump in the engine bay or in the power center. I suppose he could remove it or wire in a switch as you said. I've done it on a modified Jeep that was insured but sure didn't want to lose it.
Dec-20-2017 09:41 AM
