โFeb-04-2022 09:11 AM
โFeb-05-2022 07:49 AM
โFeb-05-2022 07:03 AM
Sjm9911 wrote:
Just note last time someone had thos problem on the pop up site, the reset switch was bad. So you can also check that to see if the power is getting through. But if the fan is working, it probably is getting power. There is also a limit switch on these also. So , if its not the sail switch it could be the limit switch. Not sure if the fan would work if it trips or not. Usally its a sail switch. While you have it apart, good idea to clean the flue and make sure there are no obstructions in the vent pipe.
โFeb-05-2022 06:45 AM
โFeb-05-2022 06:39 AM
โFeb-05-2022 06:21 AM
Amateur Radio K3EXU
โFeb-05-2022 06:16 AM
โFeb-05-2022 06:11 AM
โFeb-05-2022 06:10 AM
โFeb-05-2022 04:38 AM
โFeb-05-2022 04:06 AM
โFeb-05-2022 12:27 AM
โFeb-04-2022 10:06 PM
โFeb-04-2022 11:54 AM
โFeb-04-2022 11:40 AM
