โNov-14-2017 09:01 PM
โNov-15-2017 11:08 AM
โNov-15-2017 08:57 AM
โNov-15-2017 08:37 AM
โNov-15-2017 08:12 AM
โNov-15-2017 08:05 AM
โNov-15-2017 07:37 AM
โNov-15-2017 07:09 AM
โNov-15-2017 06:24 AM
valhalla360 wrote:
When you drain the oil, there is always a little left on the surfaces. With a diesel, it turns black due to soot. You just mixed the new oil with the old sooty oil. You just can't visually see that the soot is drastically thinned out.
As far as helping reliability, your average new engine will outlast the chassis just following the manufacturers maintenance plan, so there is nothing to gain by putting suspect used oil into the engine.
โNov-15-2017 06:13 AM
โNov-15-2017 04:59 AM
naturist wrote:
Modern engines bear little resemblance to engines of even 20 years ago. Oils today bear little resemblance to oils of even 20 years ago. DO NOT UNDER ANY CIRCUMSTANCES EXPECT TECHNIQUES THAT WORKED *THEN* TO BE HELPFUL TODAY!!!
โNov-15-2017 04:32 AM
โNov-15-2017 03:46 AM
โNov-15-2017 03:23 AM
โNov-15-2017 03:19 AM
โNov-15-2017 03:14 AM
