โJul-04-2023 08:57 AM
โJul-11-2023 09:45 AM
Boomerweps wrote:
My two legged dinette table initially did the hippy hippy shake. I measured the table and found the legs off center in EVERY way possible. I remounted the leg bases, on the floor and table and mounted the table top so it rests against the wall. Very little movement now.
Because the table is made to be removable, it will have some movement. Nature of the beast.
โJul-11-2023 08:13 AM
โJul-06-2023 01:51 PM
JimK-NY wrote:
I had a similar issue. The ends of the tubes are crimped inwards so that there is initially a good fit. Eventually wear caused a loose fit and I had to replace the tubes.
You might want to start over with an entirely new table mount system. I went with the Lagun and really like it. Check out the videos.
โJul-06-2023 01:46 PM
dougrainer wrote:
When secured CORRECTLY, this type table does not wobble. Odds are the floor mounts have stripped out their screws. Fix is to remove both floor mounts and rotate about 1 inch to get the mount screws to hit fresh wood. Doug
It is VERY common for this type table system to come loose. When in table mode, pushing and pulling by the diners cause the mounts to strip out in the wood floor.
โJul-06-2023 01:43 PM
fj12ryder wrote:
Is it wobbly because it fits the floor sockets loosely? Ours got wobbly because the floor socket cracked, fixed it by replacing the floor socket. Maybe the socket on the table isn't mounted solidly. Describing where it's wobbly would help. Do the legs not fit solidly into the sockets?
โJul-06-2023 01:42 PM
CA Traveler wrote:
Try some tape for a shim and if resolved look for a more permanent shim.
โJul-05-2023 09:48 AM
โJul-04-2023 02:14 PM
โJul-04-2023 12:44 PM
โJul-04-2023 11:48 AM
โJul-04-2023 09:11 AM
