Shore power with out battery connected
Billstigger
I am wondering if it is acceptable to have shore power hooked
up with the battery removed. I have an Artic Fox 30U, and normally
enter and check things out 2/3 times during the winter. For safety I
do not want to leave it plugged in constantly, but just flip the breaker when I want to.
4 REPLIES 4
beemerphile1
It would be most helpful if you tell the model and brand of converter. Otherwise all you will get are guesses.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Bobbo
It really depends on what converter you have. Give us its model name and number and we can give you specifics. Most of them are OK with that, but a few aren't.
Bobbo and Lin
RJsfishin
An '04 RV should have the power supply type converter, so yes it should be fine w/o a battery.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
janechucknicode
It all depends on what you wish to have it plugged in "for". I would leave the battery on and don't worry about it, you do or will have some items that like to drain the battery "stereo" and such.
Also it isn't good for a battery to be left by it's self. If you are going to disconnect. Remove it and store it in a dry area NON freezing and keep a trickle charger on it.
You will not have lights or most items that run with 12 v if you disconnect. Remember to check the fluids in the battery very month , to save you a headache when you do want to use it and keep it charged.
Good luck
