โAug-27-2013 05:07 PM
โSep-01-2013 02:58 PM
6dot6 wrote:
Yeah those filter heads are crappy. I got rid of mine with a lift pump. Went with a big dipper trans out of maryland. Lol yeah that was my gl hero 3 which is somewhere back at best buy because it was a pos and was freezing too much. I would imagine you can hit a high 13 with a stock trans tune. Efi with idaho rob or kory willis and you cant go wrong. Love my truck.
Nice myrtle beach sounds awesome right about now. I just got back from a 7 day maine trip and it was amazing up there. Saw my first wild moose eating like a deer on the side of the road and the wolves howling at night over the huge lakes was awesome.
โAug-31-2013 06:50 AM
โAug-30-2013 05:55 PM
6dot6 wrote:
Crew cab long bed 4x4 ๐ see if you can watch this. Its a little long but im not good at editing.
http://youtu.be/FKJtdvbwLVk
โAug-29-2013 02:30 PM
โAug-29-2013 11:16 AM
ADAD437 wrote:
when i am in one place for an extended time i have the extend a stay hose set-up and two 30# tanks i use and shut off the main tank. You might want to look into this. i use it so i don't have to move the rv for propane.
6dot6 wrote:
I would def try one of the grill ones. Btw how is the one on there attatched? If you can take it off i would def use a tank that might just be reusable and removable? Hopefully you can trace the gas line and maybe unwind it atleast temporarily. Crazy how it rusted on you i never heard that.
Thanks btw. I was happy with the time she ran, def has more. Had a poor 60' time. I think shes somewhere around 630-640 ish at the wheels. With the stock turbo i pulled a 13.3 no weight reduction. You will be so happy getting some exhaust and tune setup. Cant go wrong with idaho rob or kory willis efi tunes. ๐
โAug-29-2013 04:36 AM
flash.flood wrote:6dot6 wrote:
I guess maybe the newer models are coming with both gas and electric? This is my first camper and i have both but by your reaction thats not the case. Can you attatch a small propane tank to it?
Great minds think alike. I was driving around in my dually today trying to find a place that can make me a custom a/c line for the motor home because the condenser blew a hole and has been discontinued. The only option is a newer unit but the upper hose won't connect do to the angle. That got me thinking about bringing a small tank from our grill and just attach it to the line since I have to remove the old tank anyway. A replacement tank is $500. I wonder if the existing tank can be welded. I could fill it with water and flush it out really good. Welding a tank like that makes me nervous but what do you think? It's just one small spot on the existing weld.
btw. Impressive numbers from your dually. I have an 07 Classic and am thinking about trying to get a little more out of it. Not twins but maybe a tune and exhaust.
James,Gail & Pancho
2005 georgie boy Pursuit
โAug-28-2013 06:22 PM
โAug-28-2013 03:48 PM
โAug-28-2013 01:28 PM
โAug-28-2013 10:01 AM
6dot6 wrote:
Disconnect and open it. Prolly some haters but i had some tanks leak out on me before. Its a natural gas. I wouldnt let that stop me. If you have electric hotwater go camping. Use charcoal to cook. Its fun when things go wrong, its a story to tell later on.
โAug-28-2013 09:52 AM
โAug-28-2013 06:34 AM
westend wrote:
Edit: reread your initial post and see you have a MH so the tanks are fixed, right? Here's what I would do: call the outfit that filled it, tell them to roll a guy to your location with the necessary connections and tank to bleed yours off.
If you have any spark producing devices, make sure they are off. This means, if you're connected to shore power, turn the power off at your pedesatal or inside the load center at your house. DO NOT attempt to remove the cord from your coach. If you have a battery disconnect switch, turn it off to all banks. Wait for the cavalry and stand back from the coach. If you can open a door or window to the coach without creating a spark, you might try. It might be better to just keep away.
If the outfit that refilled your tank won't come to the rescue, call the Fire Dept..
โAug-28-2013 06:19 AM
โAug-28-2013 06:17 AM
