Single or double battery box
marquette
When converting from a 1 battery system to a 2 battery system are most people using 2 single boxes or one large 2 battery box?
4 REPLIES 4
SoundGuy
opnspaces wrote:
I use separate boxes on my trailer.
The answer as to whether one larger box or two separate boxes is preferable depends on which allows best utilization of the space available. Soon I'll be reorganizing my trailer tongue, moving the two propane tanks further back and mounting the battery or batteries in front of them, just aft of the tongue jack. The battery closest to the tanks is actually going into a lockable tool box I've selected that is large enough to hold a G31 battery. In front of that I still have space to mount a G31 battery box that will hold either my fresh water transfer pump or a second battery, a decision I'll make later based on our needs as the camping season progresses. Now only if this crappy "winter" weather will leave! :M
2012 Silverado 1500 Crew Cab
opnspaces
Navigator II
Navigator II
Boon_Docker
I use a "2 battery" box, that way everything is nice and neat in one box.
time2roll
