โMay-07-2022 04:48 PM
โAug-04-2022 09:54 AM
โAug-04-2022 08:30 AM
โAug-03-2022 03:58 PM
โAug-03-2022 02:47 PM
โAug-03-2022 09:31 AM
โAug-03-2022 08:39 AM
โMay-10-2022 05:52 PM
โMay-08-2022 10:35 AM
JoshInReno wrote:
Hi everyone, it's been awhile.
I have a new to me trailer and have run into a problem:
The bedroom slide will not move on 12v power. It just clicks. The kitchen slide works fine on 12v so I don't suspect the battery but it's possible.
The bedroom slide works fine on 120v so I assume the motor and gearbox are fine. It should be noted I have yet to even find the motor and gearbox. The slide has arms, not cables so I suspect the drivetrain is under the slide but it's an enclosed underbelly that I don't want to start cutting into just yet.
Any ideas?
โMay-08-2022 08:39 AM
jdc1 wrote:eHoefler wrote:
All systems on the trailer are 12 volt. Since it operates when plugged in, it will be a battery issue. Have your battery tested, if over 3 years old, replace it.
I agree. Try using a different battery (even your truck battery).
โMay-08-2022 08:08 AM
โMay-08-2022 07:00 AM
โMay-08-2022 04:56 AM
โMay-07-2022 11:10 PM
โMay-07-2022 05:59 PM
