โMar-24-2013 08:52 AM
โMay-16-2013 09:07 AM
โMar-25-2013 09:06 PM
โMar-25-2013 08:54 PM
skipro3 wrote:
Check all the connections and make sure they are good. Also, get that manual crank fixed or replaced. Just to be extra safe, figure out how to access the motor and add a wire so you can hook up a remote battery directly to the motor to run it, in case the control board acts up and the crank is broke again. You can never be too careful!!
โMar-25-2013 08:48 PM
โMar-25-2013 08:13 PM
mike740ski wrote:
.... I am going to power everything down again one more time (Lance technical support just emailed me with that suggestion)..... .
โMar-24-2013 09:56 PM
mike740ski wrote:
The schematic shows no fuse in the activation switch panel. The remote activation switch panel (located by the stairs and door)is connected back to the controller base receiver (which is under the cabover step) via a phone cable, that's it. I did try plugging in the remote directly into the activation switch via the cable that comes with it. That did not work.
โMar-24-2013 09:22 PM
BFL13 wrote:
Does the remote box have a fuse in it? How about where the remote plugs in ? Or where the wire goes into the remote box?
โMar-24-2013 09:15 PM
skipro3 wrote:
Your red and blue lights are not coming on. The red light should come one when you push the activate button and it should also come on when doing a power-off-reset. The blue light comes on when it receives an RF signal from the remote. Since you don't have a red light, you'll never get a blue light. Do your remote control jacks work? Most likely not since you don't have the red light. This isolates it to the controller board located with the battery under the cabover step. Since you can't get to the step with the slide in, you'll have to fix the manual crank and get it out. Don't forget the brake switch. There's a switch that requires you to disable the electric brake so the manual crank can work. WAIT! If that brake switch is not set right, then the remote won't work and the red activate light won't light. Maybe it's the brake switch you need to toggle. Keep us informed I have a 2012 Lance 855S and have had every known and many unknown problems with mine. I've fixed them all and I know how those things work.
โMar-24-2013 09:05 PM
โMar-24-2013 07:04 PM
โMar-24-2013 06:33 PM
Bill T wrote:
Mike try removing all power from camper. Disconnect shore power, unplug pigtail from truck and disconnect battery. Let unit sit for about 30 sec.s then power back up. This takes care of it for me. And be sure the remote batteries are good..
There is a fuse on the jack/slide control module, I think it is a twenty amp. On my unit there is a circuit breaker in the line to the slide motor, near the motor. But I do not think that would have a bearing on your problem.
โMar-24-2013 10:03 AM
