Smoke alarm
smiledr
This must be an easy fix but I am at a lost. Pulled our 2016 Navion Itasca out of storage to load up for our trip to Colorado and the smoke alarm is beeping every 20 seconds or so. I have replaced the 9v several times. It is hardwired with battery backup. No brand name that I can see anywhere. Reset circuit breakers. Still beeping. Any ideas?. Please.
smiledr
15 REPLIES 15
dougrainer
garyemunson wrote:
Stop by Home Depot/Lowes and just get the right thing. The ones with hard wires are standard home detectors. The only difference maybe the plug and every one I have bought comes with a plug that matches the new detector so you can change out the old plug if necessary. I'm pretty sure the heat and cold in a stored RV has a detrimental effect on detectors that, for the most part, expect to live in a climate controlled space. Myself, I don't mind having to replace them sooner than in a house (detectors should always be replace every 10 years) just to be safe.
I doubt HD and Lowes have hard wired 12 VOLT detectors. From the OP post, he did not state if it was 120 hard wired or 12 volt Hard wired. The only Hard Wired I have seen in RV's was 12 volt. Doug
garyemunson
wa8yxm
That is an indication of "I'm too old" as well as "Dead battery". Like others said. Get a new one.
smiledr
Thank for your help!
smiledr
IAMICHABOD
pennysmom09 wrote:
ksg5000 wrote:
I find that hardwired smoke detectors are unnecessary and often PIA. Suggest you toss and buy an inexpensive battery operated combo fire/CO detector - you have to change the battery once a yr. No big deal.
I agree. We did this too after being annoyed by the hardwired one.
I also agree,my hardwired one failed and the replacement was not being made anymore.
After a lot of research I settled on This one change out the batteries once a year.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
pennysmom09
Nancy and Doug
2015 KZ Durango 325RL FW
ksg5000
Kevin
dougrainer
Have you checked the voltage on the HARDWIRED battery wires at the detector. If you have LOST the 12 volts to the Detector, the beeping may indicate THAT and not the low power of a 9 volt battery when you have a 9 volt Battery ONLY detector. Doug
DrewE
The wires attached to the smoke detector are (almost certainly) short, maybe 6", pigtails, and are joined to the RV wiring in the wall or ceiling. You should be able to pull them enough to access the joints and detach there. In my RV they used wire nuts, taped to prevent them from working loose, for all those sorts of connections; but there are a few possible methods that could be done. (I know some will say that wire nuts are no good for RVs, but so far all the wire nut connections in mine have been trouble-free.)
As BB alludes to, make sure you insulate the loose wires somehow or another so they can't short out.
BB_TX
You can cut both wires. Just make sure you cut one, tape it, then cut and tape the other. Donโ€™t cut both at the same time with metal snips or they will short.
smiledr
I think I will buy a 9v one at big box until I get this one replaced. To disconnect from RV power do I cut the red wire?
smiledr
LadyRVer
Sounds like it bit the dust. To silence, I have used one of the little elastic bowl covers or put plastic wrap on it. Not very safety wise... just what I have done .
Bobbo
Remove backup battery and disconnect RV power. Not recommended unless you go to a big box store and buy 9v one for now.
Bobbo and Lin
smiledr
Not what I wanted to hear the day before a trip. Any way to silence it until I get it replaced?
smiledr
