โMar-14-2023 06:55 PM
โMay-04-2023 04:32 PM
โMar-15-2023 07:03 PM
KD4UPL wrote:
Clamps are a poor means of connection. Bad connections cause heat. However, that little panel shouldn't generate enough current to make much difference.
Did you install a fuse on the positive cable near the battery? It should have one to prevent this sort of thing.
Do you have a charge controller or did you just hook the panel straight to the battery? You really should have at least a basic charge controller to keep the battery from being over charged.
I'm going to guess a cheap solar panel that shorted out with no fuse or charge controller to protect it.
โMar-15-2023 06:07 PM
โMar-15-2023 11:15 AM
โMar-15-2023 09:25 AM
โMar-15-2023 08:56 AM
โMar-14-2023 08:22 PM
